I'm trying to understand why they would use a different one from the negative side.
wk057, Could you please list the part number for the positive contactor? I'm trying to understand why they would use a different one from the negative side.
Pure speculation: nothing to do with positive/negative per se, but one of the contactors needs to have breaking capacity to be opened under full load. The other one can be sequenced so that it only opens/closes under no load, and so can be smaller.
Hi wk057, just found the battery wiki page on here.
http://www.teslamotorsclub.com/showwiki.php?title=Battery table&redirect=no
Looks like S85/P85/P85+ shared the same battery near enough.
May be just rolling upgrades, but from the latest results it does look like the P85D battery could be different (fuses?), and also the 85D is up-revved against all the others so could be just another variant or something altogether new?
Cue the new cells speculation, though imho I doubt it. Need a few mor recent reports eg 70D tbh.
Do you have any insight on this?
Agree totally re 70D structure.
Curious that the last entry in the table (at the time of writing) ie the first 85D has a noticeably different pack nr though.
In theory this is just an 85KWh pack capable of same power as the other 85 models before it.
Would be interesting to see a teardown of a P85D pack to see which details are changed (if any), this would unfortunately mean a P85D write-off, so liely no volunteers!
My standing guess, until I see evidence to the contrary, is that the 70D simply uses 14 of the same modules used in the 85 pack (which uses 16) and they're just marketing it as the 70D instead of the 74.375D. This would just give it a hair extra buffer for low discharge vs the 60/85 which is fine.
It's possible the 70 pack could have 13 of the 85kWh type modules instead (12 in the back and one in the nose for balance) which would be 69.0625kWh... round up to 70 for marketing.
Either way, the only thing that makes sense is just switching to using the same modules as the 85kWh pack, since it eliminates the 60-type module, which has fewer cells, entirely. Streamlines pack production a bit more. Now the only choice will be 14 or 16 modules.
The P85, P85+, and S85 definitely have the same battery pack. The two packs I received were from an S85 and P85, and they were the same modules and same main pack fuse.
The P85D/85D packs likely have slightly larger main pack fuses and *maybe* slightly larger cell level fuses... but I doubt the latter now that I've tested the cell level fuses.
As for new cells, speculate all you want, but I'm guessing we won't see any new higher density cells until Model 3.
Humm... The voltage is not the same on a 60 and a 85...So many things rely on the voltage being the same across models.
I'm having a hard time going with your 70kwh design theory. Fewer modules would require a re-designed charger, re-designed inverter, different BMS, and far more differences in firmware. There's a reason the 60 used the same number of modules. So many things rely on the voltage being the same across models. Tesla has already set a precedent with keeping the voltage the same across pack sizes. I see no reason why they would change that, and lots of reasons why they would go with the same number of modules in the 70, just fewer cells.
Yes, so there are two venues toward 70kWh:The 60 pack does only have 14 modules. And it also has fewer cells in those 14 modules.
- 16 modules of those 'fewer-cell' modules (69kWh)
- 14 '85kWh-pack modules' (74kWh)
Part of the answer will be packs nominal voltage. If it stays at 350, it will say 14 modules. If it says 400V, it will mean 16 modules.
The other part of the equation will be weight - how will its mass relate to S60, S85 and S85D.
What doesn't ring right is why would tesla increase price of the battery for 16% (assuming same cells as in 85 just more of them) and only increase end price a tiny bit, reducing earnings / car.
As for the price... in the absence of any verifiable data, I think everyone tends overestimates the battery cost to Tesla for some reason. Even using a high estimate like $400/kWh, adding 10kWh would be ~$4000. The cash price of the 70D is something like $6000 higher than the 60. So, I don't really think they're taking a hit.
Right, if someone supercharges the 70D it'll be very easy to tell from the peak voltage how many modules it has. Just for reference:So, not sure until I see a 70D supercharge voltage screenshot.
