Yes.Is that if you integrate for power delivered ("area under the curve") while discharging a battery the area=total power delivered will vary depending on the slope/shape of the curve i.e. the use case (faster/slower discharge, average discharge rate, bursts etc.)?
But industry standard is not to integrate but to cut shortcuts using 3,6V or 3,7V as a magic number.
Nope.If so, aren't Tesla just adhering to industry standards as they rate their big pack at 85kWh.
85.000Wh / 7104 cells = 11,965 Wh/cell
wk measured those cells a bit under 3000mAh. To reach 11,9Wh at 3Ah, the nominal voltage would need to be 3,99V. According to the picture above also this is clearly not so.
One could probably stretch those cells a bit higher and lower but I just cannot see how can you stretch them to reach 11,965 / 3,6 = 3300 mAh or even 11,965/3,7 = 3230 mAh
