He said one of his coworkers ordered that part and corrected the problem with another Model S .Thanks for that info! I added it to my service ticket. Hopefully we can get that ordered and replaced on mine.
Others have replaced that and it NOT fix the issue. I still say its a supplier issue, whoever is supplying the console is at fault so luck of the draw if the replacement has it or not. Chances are good though that the issue has been out long enough that MOST of the stock should be good now but who knows.....He said one of his coworkers ordered that part and corrected the problem with another Model S .
That's exactly how mine works after the SC fixed it. Took him a few days until he figured out that one switch was different than the others but now it works perfectly.I don't believe anyone has gotten this issue fixed at a service center. Swapping switch connections did make it work better as was shown in William G's video but this certainly not how it 'should' be working. My console was then 100% replaced and this put it back to the original state. To me, everything points to a logic flaw in the controller (possibly firmware programming).
A closed lid should disable ALL Lighting, both lower bin and tray lighting.
A fully open lid should enable the lower lighting in every configuration EXCEPT if BOTH cup holder and slide tray are visible.
Slide tray should only be lighted when extended and NOT COVERED by the LID in its middle position (half open).
Here is the wiring diagram (ignore markups) for your diagnostic pleasure, hopefully it remains readable:
In the diagram, is it showing that the switches are in series with the LEDs or is that just a connector or junction?I don't believe anyone has gotten this issue fixed at a service center. Swapping switch connections did make it work better as was shown in William G's video but this certainly not how it 'should' be working. My console was then 100% replaced and this put it back to the original state. To me, everything points to a logic flaw in the controller (possibly firmware programming).
3 switches at the bottom feed directly into the controller. The controller evaluates these three conditions and decides when to provide voltage to each of the two LED drive circuits, (BIN and TRAY). The BIN circuit drives 2 LED's in parallel. The TRAY circuit also a switch in series that blocks power to the TRAY LED when it is stored. In all cases that I've read about so far, the TRAY switch is working fine.In the diagram, is it showing that the switches are in series with the LEDs or is that just a connector or junction?
There appears to be an inline connector junction in series with each circuit, X982 and X983.In the diagram, is it showing that the switches are in series with the LEDs or is that just a connector or junction?
I thought the switches only detected the fully stowed position for the small tray and lid. Basically the car knew if they were either fully open or not fully open. Nothing in between like half open vs fully open with a simple switch. Good to know there is also a cupholder switch, no light there so they definitely intended to have some more advanced logic.
Edit: something is up with the diagram, the control pin labeled c2 says high side drive (voltage) but it runs to a switch with no load, no led like the other drive lines. Might be a dynamic pin but I'd think that should be a sense line for the front bin switch.
He said that 2 of the switches are ON when pressed, while the 3rd was OFF when pressed. He then said he had to look around to find the right part, but it wasn't quite clear if they were supposed to be all the same but were as described or if they are supposed to be as described and were all the same.Did he say how it was different and what exactly he did to fix it? Part replaced, re positioned, swapped connector pins, etc..?
I sure would like to know the details..
Maybe, I'd think they'd just call it a sense line unless that was the existing call out for that pin on the left side body controller schematic. Could be a common part for x/s or even 3/y with different functions. Based on the wiring and assuming the controller can be updated via ota, they should be able to work this with firmware then, just swap the normal state of the lid switch from NO to NC or the opposite. look for ground instead of open circuit for just that one line.Yes, C2 is a logic input state to the controller. The wording is confusing but I think maybe it was intended to show it has primary inhibit authority over the BIN Drive circuit
It's gotta be the switch on the c2 line, wish we had the part numbers!Did he say how it was different and what exactly he did to fix it? Part replaced, re positioned, swapped connector pins, etc..?
Yeah, that's my fear, eventually they'll "fix" it via software and then all of us that fixed it via hardware will have it wrong again.Maybe, I'd think they'd just call it a sense line unless that was the existing call out for that pin on the left side body controller schematic. Could be a common part for x/s or even 3/y with different functions. Based on the wiring and assuming the controller can be updated via ota, they should be able to work this with firmware then, just swap the normal state of the lid switch from NO to NC or the opposite. look for ground instead of open circuit for just that one line.
The only light that is directly activated by a switch is the small tray, and they even have some logic control there via the drive line.
Also check my earlier post where the tech who fixed it had to figure out that one of the switches activates when released as opposed to when pushed.
Could you possibly post a video of how yours is working correctly in every configuration?That's exactly how mine works after the SC fixed it. Took him a few days until he figured out that one switch was different than the others but now it works perfectly.
For another data point. Mine worked on delivery (June 3, 2021 build) exactly as the video by @WilliamG . It stopped working correctly after the top of the center console was replaced. After a service appointment it now works as it originally did. I am sure this is how it is supposed to work.Could you possibly post a video of how yours is working correctly in every configuration?
As I said before, I believe that the video offered by WilliamG showing how it should work is mistaken. It would be good to have a better example to confirm what is what.
From inspection, the switches and harness wiring are not attached to the lid. The whole console upper section is a complete module. Sandy Monroe's group showed what it looks like all torn appart. Too bad they only talked about the mechanical features; the wiring and switches were already removed.No, just the lid with attached switches and harness.
@WilliamG 's video shows that the lower bin is only illuminated when the lid is fully opened. This cannot be correct. I say this because this simple operation can be accomplished using only 1 lid switch and 1 tray switch (2). We know for a fact that there are 4 switches involved. There is a switch for the cup holder position and one for the half-opened lid position detector. These sensors should have a functional effect on the lighting scheme. They don't in Williams video.For another data point. Mine worked on delivery (June 3, 2021 build) exactly as the video by @WilliamG . It stopped working correctly after the top of the center console was replaced. After a service appointment it now works as it originally did. I am sure this is how it is supposed to work.
I’ve not heard of anyone’s new S working “better” than this. Happy to be proven wrong, of course.@WilliamG 's video shows that the lower bin is only illuminated when the lid is fully opened. This cannot be correct. I say this because this simple operation can be accomplished using only 1 lid switch and 1 tray switch (2). We know for a fact that there are 4 switches involved. There is a switch for the cup holder position and one for the half-opened lid position detector. These sensors should have a functional effect on the lighting scheme. They don't in Williams video.
I like data points however I remain a skeptic. Most of the data so far indicates a majority that all work the same. i.e. wrong.
