Wipers and mirror adjustments are all in the first layer of the main settings menu. Wipers settings are also available by clicking the end of the stalk - same as before.Wipers, Defrosters, Mirror adjustment, and Fog Lights need to be made more easily accessible.
Bring back the Cards for Odometer and Tire Pressure.
Move Side Warning Camera screen to TOP Left of Display.
All these are IMPORTANT SAFETY FUNCTIONS. They should not be hidden under 3 layers of menus!
Defrost is in the first layer of the HVAC menu with larger touch targets than before.
Odometer is two taps just like before if you used the settings menu to see it. If you used the cards to access the odometer, it took a minimum of two swipes depending on which card was currently displayed (a swipe left to get to trips, then a swipe up to get to the bottom of the trips card). Two taps vs at least two swipes?
Tire pressure is now two taps as opposed to at least one swipe depending on which card was being displayed.
I agree that fog lights should be on the main settings page instead of in the light menu (second layer), but I’ll survive. I appreciate the new quick lighting menu when activating the high beams.
Contrary to your claim, none of these functions are three layers deep.
