WilliamG
Hinge Fanatic
Yes, I have that vibration. I thought you meant some vibration when not accelerating, since you had said “The start up vibration for example occurs without any acceleration“. That startup vibration is still under load, and requires throttle input in my testing. Also, I don’t believe this Service Bulletin is related to it specifically, because that vibration does not affect 2021 Plaids, only 2022 and 2023 models. The TSB mentions 2021 models, too…The startup vibration is the one that only exists for the first few minutes of the drive and usually becomes noticeable around 33mph in my case.
I think that startup vibration is a cousin of the ~40-50 vibration, as they feel very similar (the startup vibration is a more aggressive version of the persistent 40-50 one).
Time will tell. It may address this vibration and the 40-50mph vibration, or just the latter, or just the former (and the TSB mentions the 2021 model then maybe by mistake). Until someone reliable (e.g. me! ) gets it, we won’t know. I suspect it may solve both, or - at least I hope so. If it has to solve only one, then let it be the persistent 40-50 one. The startup one is so fleeting as to not be a big deal in the grand scheme of driving.
