There is also a very small amount of power pulled directly from each module, to power the isolated part of each BMS module monitoring/balancing circuit. This is the case even when all the balancing resistors are switched off. Also the case when the pack is removed from the car and even when the modules are removed from the pack (per the pack tear down thread). While the current amount is certainly very small, it is active 24x7 across each module. Unsure if's enough to really matter though w/r/t vampire drain estimates given here.I always wondered how much power the BMS used. But I'm not sure that's it. For one, isn't the BMS powered off of the traction battery? Vampire losses occur when the car wakes up and slowly discharges the traction battery to charge the 12 V.
My P85D on firmware 6.1 (2.2.113) seems to be losing about 1 rated mile every 4 hours. It's been this way since I got the car on firmware 6.0. For example, if my car finishes charging in the evening and I don't use it until the next morning (say 12 hours later), then I typically lose about 3-4 rated miles. Are other P85D owners experiencing this?
Do you have sleep mode enabled and always connected unchecked? FWIW, with sleep mode I lose 3-4 miles/24 hrs.
