Did you hear back from them about Canadian orders? TIAI’ll order if they can do Canadian as well. Vendor says they are seeing if they can get it sorted.
I tried the coupon code and it doesn't work on the Canadian site.
Nope, vendor said they'd get back to me but has not yet, and also that I was the only Canadian interested... seems that last part might not be true. Have you tried to contact the vendor directly?Did you hear back from them about Canadian orders? TIA
No I haven't. I'll do that tomorrowNope, vendor said they'd get back to me but has not yet, and also that I was the only Canadian interested... seems that last part might not be true. Have you tried to contact the vendor directly?
I just contacted them via FB MessengerNope, vendor said they'd get back to me but has not yet, and also that I was the only Canadian interested... seems that last part might not be true. Have you tried to contact the vendor directly?
I just received mine today, however, I had it shipped to Washington State (I'm a 20 minute drive from Point Roberts, WA). I'm not sure where you live, but if you live near the boarder, that may be an option.Nope, vendor said they'd get back to me but has not yet, and also that I was the only Canadian interested... seems that last part might not be true. Have you tried to contact the vendor directly?
I haven’t yet installed my frunk kit, but with my stock Plaid hood and latch I can push down on the hood about 1/2” when it’s locked in placeI did mine today not bad at all except it took a while working in the latch position, for those you have done it I can still press and move my hood. The vendor says it is normal and it shows closed in the main Tesla screen. Are your cars like mine Where you can still push down a bit on the hood when closed?
Ok, thanks I feel better now.I haven’t yet installed my frunk kit, but with my stock Plaid hood and latch I can push down on the hood about 1/2” when it’s locked in place
I thought the same thing when I was done but hadn't specifically looked at the movement before so I couldn't tell if it was different. That said, I washed the car over the weekend and didn't see any signs of water in the frunk so it appears to still be sealed.I did mine today not bad at all except it took a while working in the latch position, for those you have done it I can still press and move my hood. The vendor says it is normal and it shows closed in the main Tesla screen. Are your cars like mine Where you can still push down a bit on the hood when closed?
Have you contacted EVOffer's tech help? I found them to be extremely helpful and very easy to work with. It may take a little while for them to respond initially as I'm not sure where exactly on the globe they are so there is likely a significant time difference but once they responded to me, it was a quick back and forth text conversation. They were often answering questions while I was still typing my next comment.I meant to say travel distance. But that may only be for the opening. Any way to manually adjust the struts? I haven’t attempted the install yet and am kinda just throwing out ideas.
Yes I contacted them via Telegram last night at 6pm EST and haven't heard anything back yet. I re-pinged the conversation this morning in case they missed it.Have you contacted EVOffer's tech help? I found them to be extremely helpful and very easy to work with. It may take a little while for them to respond initially as I'm not sure where exactly on the globe they are so there is likely a significant time difference but once they responded to me, it was a quick back and forth text conversation. They were often answering questions while I was still typing my next comment.
I put mine where they showed it in the instruction manual. I used the double sided tape provided to give it some anti-vibration insulation and the long zip tie around the frame as shown in the pic below. hope this helps.Can anyone who finished this show where they stowed the latch motor? I know the directions suggest putting it near the wheel well for an emergency but I don't see anything good to zip-tie near there.
