I've noticed that doing nothing more than turning on Climate when it is cold (below freezing), pulls down the maximum 48 amps for a while. If it is below 0ºF (-18ºC) it will pull maximum current for quite a while (hours). But it sure does reduce initial battery drain after departing.The battery needs to be much warmer than normal for maximum supercharging. This is only done when you enter a supercharger into the navigation and it’s far enough away to heat the battery sufficiently.
Regular preconditioning only prepares for normal driving so you have better power and better regen. Note that the cabin warms up much faster than the battery so even if you precondition and the app says desired temperature is reached, the battery still might not be warm enough to provide full regen.
Yep it’s trying to heat the battery to optimum operating temperature even after the cabin has reached temp.I've noticed that doing nothing more than turning on Climate when it is cold (below freezing), pulls down the maximum 48 amps for a while. If it is below 0ºF (-18ºC) it will pull maximum current for quite a while (hours). But it sure does reduce initial battery drain after departing.
We're discussing optimum use scenarios here. There actually is no need to wait to drive. Unlike an ICE vehicle which operates much better when warmed up. A Tesla (or other EV for that matter) does not need to warm up before use. However, if you know in advance when you are heading out, and the vehicle is plugged in to shore power, an extra hour of Climate being on is helpful. It reduces the battery charge consumed by heating the battery before you leave, using shore power If you are not plugged in, then don't worry about early heating beyond creature comfort.Yep it’s trying to heat the battery to optimum operating temperature even after the cabin has reached temp.
It doesn’t tell you when the battery as reached optimum temperature though as it can take a while depending on how cold it is and it doesn’t want people to be waiting hours for the battery to warm up thinking they can’t drive it until it’s warm.
First off, there is no harm to the battery in either scenario. if it is bitter cold outside (0ºF). If you turn climate on say for an hour before she leaves, it may reduce energy consumption while she is driving, as long as the car is plugged in. The app will tell you when the battery heating is happening, with the snowflake displayed. If your garage is truly 50ºF, that may be enough. But it won't hurt to turn climate on if the car is half warm already. It also somewhat depends on how much she needs every last drop of energy. My typical day uses less than 10% of capacity, so it is not really a big deal. But if she needs 80% to get through the day, it might be helpful. It could avoid a mid day charging stop.Seems like a complicated topic, so let me ask a question in the hopes you can steer me correctly.
Scene:
Will be wife's car. Garage kept, never below 50F in the winter. On the other hand she leaves work at 0F oft enough, and at random times.
Question:
How long before she departs should she launch precondition such that the battery is warm enough to not cause undue drain (really harm to battery, which I infer is the same)?
So the "don't worry about harming the battery" point has been sufficiently repeated already, but FYI (because you may never experience this), the top side of the IC energy chart (draw side) can show dashed lines the same way the bottom side (regen side) does when the battery is fully charged or cool enough to merit limiting regen. I should imagine this would occur in any scenario where limiting power consumption is merited. To be clear, I'm not sure I've even seen this in mine, but I've at least seen a picture showing it somewhere some time ago.Question:
Thanks for any insight you can share.
50ºF is not warm enough for full regen, but AFAIK, preconditioning doesn't target full regen (or even as much regen as is already available at 50ºF, so turning on climate won't help with that. One can schedule charging so that the battery will be warm enoug for full regen, though. OTOH, if you meant so that the vehicle is already heated and not using more energy to heat right at the beginning of the drive, then pardon me, as you ae correct, adding another 10ºF of so to the cabin from shore power certainly won't hurt.If your garage is truly 50ºF, that may be enough. But it won't hurt to turn climate on if the car is half warm already. It also somewhat depends on how much she needs every last drop of energy.
Your confusion is understandable because Tesla did something really legitimately confusing here. They used the same word "preconditioning" to mean two totally different things in different contexts, which have two different functions.I preconditioned this morning and sent to a SC near by but charging was slow and the screen said it needs to heat the battery. I thought preconditioning is the same?
"Preconditioning" while the car is parked is like for warming up the cabin. And if the battery is really cold, like below freezing, it will also warm the battery up some to get it to a medium temperature, which is a bit more comfortable for your driving, so your regen doesn't feel really limited.
But that is not the same thing as "preconditioning" for Supercharging. That previously mentioned kind of warming up to medium temperatures while parked isn't nearly enough for fast Supercharging speeds. That needs to get HOT. And that only happens while the car is in Drive gear, and the navigation is set to go to a Supercharger. In that condition, then the word "preconditioning" means it is blasting the battery heating to get it as hot as it can to make Supercharging really fast.
I only get the message when navigating to a SC and it is very cold, near freezing or below.Are you guys getting a preconditioning message on your Model X when navigating to a supercharger? I have a 2020 MXP and I'm not getting the message compared to a loaner 2020 MSLR and my 2022 M3LR.
If you are getting a message, what year and trim do you guys have?
