If you are handy with tools you can adjust it yourself, I learned how while installing my auto open / close Frunk system.
Take out the frunk liner by taking off the cowl cover, popping loose one push pin on the drivers side, pop loose the "trapped in frunk" switch, and removing 4 bolts (two at the front, two down in the bottom) this will give access to the latch mechanism. Mark the outline of the current latch position with painters tape / masking tape. Then loosen the two bolts holding the latch mechanism in place and adjust it up or down as needed.
Or, if you are not comfortable doing this just make a service appointment
Keith
