JRP3
Hyperactive Member
Your descriptive sentence works just as well with a plug in hybrid or PHEV40 label. "It's a plug in hybrid that can go about 40 miles on electricity alone." Simple, concise, accurate.
....and leaves out the distinguishing operating characteristics that are important to drivers who prefer electric drive...Your descriptive sentence works just as well with a plug in hybrid or PHEV40 label. "It's a plug in hybrid that can go about 40 miles on electricity alone." Simple, concise, accurate.
It's about what it doesn't do during those 40-some miles -- it doesn't start the engine where other PHEVs might. That's an important distinction, right?You mean it does something more than travel about 40 miles on electricity alone? What else can it do that someone who prefers electric drive should be aware of?
The important distinction is the over all EV range, the various specific details about how each PHEV handles the ICE management during the electric range simply can't be handled by a single phrase or acronym, not even a new one. REEV, EREV, etc., provide no useful data. Coming up with a bunch of unfamiliar terms does nothing to clarify it without further explanation to the uninitiated. Plus actual behavior is usage dependent. Short range city driving the PHEV Prius can operate only in EV mode I believe, same is true of the Ford, but with a longer range. I also believe that if it's cold enough the Volt will start the ICE even if the pack is not depleted. Plus can't you manually select a "charge extending" mode and engage the ICE if you wish? I think anyone seriously considering the vehicles will do the basic research into how they actually operate. The real concern is avoiding the mess GM created with it's marketing, and that Bob Lutz is perpetuating.
Yet again, you also bought it for it's ICE capabilities, without which you would not have bought it. I don't see how you can ignore half of the equation, you bought the vehicle specifically because of it's dual nature. You would not have bought a 40 mile EV.
Umm, but that's the whole point of the EREV acronym. It's a new label to identify plugin hybrids that can operate without unusual limitations while using only an electric drivetrain until the battery runs out. You can try to assert that it's meaningless but that's what it means according to GM and I think it communicates something useful and important.The important distinction is the over all EV range, the various specific details about how each PHEV handles the ICE management during the electric range simply can't be handled by a single phrase or acronym, not even a new one. REEV, EREV, etc., provide no useful data.
Nobody claims the Prius Plugin or the Ford Energi are EREVs.Plus actual behavior is usage dependent. Short range city driving the PHEV Prius can operate only in EV mode I believe, same is true of the Ford, but with a longer range.
If it's under 15F, the engine will start occasionally to help generate waste heat. That's an asterisk-level issue. I've owned my Volt for just over 3 years and 69,000 miles and I've never had the engine start because of cold temperatures in coastal California. Even in colder climates in winter, that condition will often not be met during daytime driving and when it happens it's only occasionally during a few months in colder climates. When it happens, the engine runs only intermittently. It's not a routine limitation during typical driving conditions in many geographical areas.I also believe that if it's cold enough the Volt will start the ICE even if the pack is not depleted.
Yes, but who cares? You are searching around desperately for a reason why EREV is somehow not a meaningful or useful term. Give it up already.... EREV communicates a useful idea in a single acronym. It communicates that the gas engine stays off when there is charge left in the battery except under extreme conditions (like those where Model S brake calipers are freezing up).Plus can't you manually select a "charge extending" mode and engage the ICE if you wish?
"Hold" or CS mode in the Volt IS a "blend" mode, just like the Energi and PiP! In this mode, above 70mph, the ICE has a mechanical path to the wheels:You can select Hold in the Volt because it was dumb not to be able to. Hold is a range extension mode.. However, note that the Volt does not have a "blend" mode as found in the Energi and PiP.
Isn't that the issue? If you have to make exceptions for road conditions (cold weather and mountain/hold mode) isn't acceleration just one part of it? And with newer cars like the Energi (which Ford doesn't bother to try to sell as an "EREV"), you can keep the ICE off even during acceleration using the EV mode and the EV top speed is 85mph. I think the only car that can satisfy the EREV definition with no exceptions is ironically the i3 REx.It communicates that the gas engine stays off when there is charge left in the battery except under extreme conditions
http://www.motortrend.com/features/editorial/1010_unbolting_the_chevy_volt_to_see_how_it_ticks/
How can you not see the contradiction in your statements? Simply put, the Volt needed to have both electric drive and an ICE for you to purchase it. Missing either you would not have bought it.You are right, I would not buy a 40 mile EV. I did not buy the Volt for its ICE however, as (almost) every car has one of those.
I think there is something wrong with it, I'm seeing the entire picture and you're ignoring half of it. Volt owners seem to suffer from "ICE blindness".You and I are looking at the same thing (the Volt). We both completely understand it. However we are looking from different viewpoints, so we see it differently. Nothing wrong with that, it is just human nature.
GSP
Yet we have real world examples where it only causes confusion: http://www.thetruthaboutcars.com/2012/02/fox-tests-volt-runs-out-of-juice-in-lincoln-tunnel/Umm, but that's the whole point of the EREV acronym. It's a new label to identify plugin hybrids that can operate without unusual limitations while using only an electric drivetrain until the battery runs out. You can try to assert that it's meaningless but that's what it means according to GM and I think it communicates something useful and important.
And no one has tried to pretend they can run out of charge an leave you stranded, because they have been purposely and accurately marketed as plug in hybrids, unlike the Volt.Nobody claims the Prius Plugin or the Ford Energi are EREVs.
That's the point, it doesn't really matter what the minute distinction is between the operational modes of different plug in hybrid vehicles, except apparently to some Volt owners. EREV communicates nothing to those who don't already know, and those who do know it's a plug in hybrid that can go about 40 miles on electricity. I have no idea what your Model S reference has to do with anything.Yes, but who cares? You are searching around desperately for a reason why EREV is somehow not a meaningful or useful term. Give it up already.... EREV communicates a useful idea in a single acronym. It communicates that the gas engine stays off when there is charge left in the battery except under extreme conditions (like those where Model S brake calipers are freezing up).
http://www.bmwusa.com/Standard/Content/AllBMWs/ConceptVehicles/i8/Thanks to its large lithium-ion battery, which can be charged from a domestic power supply, the BMW i8 Concept can travel up to 20 miles on electric power alone.
I think that ItsNotAboutTheMoney was not referring to the series-parallel split power path from the engine to the wheels that the Prius, Ford hybrids, Volt, and several other HEVs have.
The Ford PHEVs have a Charge Depleting mode that runs the ICE, "blending" energy from gasoline with energy from the plug. This provides max energy efficiency, and does run the engine less than a non plug-in HEV, but is not an EV driving experience (so it sucks, in my opinion). I think they also have a driver selectable "EV mode" that doesn't run the ICE in CD mode, like the Volt.
GSP
Note, BMW is marketing their i8 as a plug in hybrid.
According to Wikipedia, EV power maxes out at 68 kW which is about 91 hp. Energi owners on forums sites have said that acceleration is good in EVNow mode on city streets but is weak at highway speed and is likely inadequate for passing. In any case, the default mode is not EVNow so the engine will be started during brisk acceleration, especially at or near highway speeds or when climbing hills or other steeply graded roads. I have not driven an Energi model so I can't give my own subjective impressions.The Energi special EV mode is called EV Now and it's not a default mode, IIRC. It also limits power to 118hp and that particularly affects higher-speed acceleration.
Huh? How so? The ELR is just a Volt with less conservative software controls, a new body shell, and lots of fancy interior materials and accessories. I'm not aware that it's EREV-ness is any different.Also, GM is fostering more confusion by referring to the ELR as an EREV, even though it does not meet their own definition of EREV (a subset of PHEVs).
The "70 mph" is a bad Internet meme. In reality, the Volt frequently engages the mechanical path from the ICE to the wheels at speeds as low as 36-40 mph. In any case, the point of EREV is to keep the engine off so this is an irrelevant side issue."Hold" or CS mode in the Volt IS a "blend" mode, just like the Energi and PiP! In this mode, above 70mph, the ICE has a mechanical path to the wheels:
Ford doesn't claim the Energi is an EREV so why are we talking about it?If you have to make exceptions for road conditions (cold weather and mountain/hold mode) isn't acceleration just one part of it? And with newer cars like the Energi (which Ford doesn't bother to try to sell as an "EREV"), you can keep the ICE off even during acceleration using the EV mode and the EV top speed is 85mph. I think the only car that can satisfy the EREV definition with no exceptions is ironically the i3 REx.
LOL. That's ultimately linking to a FAUX News video featuring Eric Bolling. His ideological clown routine had nothing to do with whether EREV communicates a useful vehicle characteristic.Yet we have real world examples where it only causes confusion: http://www.thetruthaboutcars.com/2012/02/fox-tests-volt-runs-out-of-juice-in-lincoln-tunnel/
LOL. Faux News. Eric Bolling. Of course it would have happened with little if any change to "the script". However, I certainly won't deny that GM flubbed much of their Volt marketing effort. Obviously, I think "EREV" is fine but the silly avoidance of "hybrid" and PHEV was a mistake along with the poorly communicated story around the planetary gear transmission.It has everything to do with the fact that had it been marketed as the plug in hybrid which it is, nonsense like that, and like calling the Volt a $40,000 EV with only 40 miles of range, never could have happened.
I guess "hair splitting" is subjective. I don't see it that way. Ford doesn't claim the Energi is EREV so I don't think there is any confusion or dispute about that. EREV or not EREV is largely, although not entirely, about battery power output which is itself closely associated with range capacity and physical pack size and cost. As batteries improve and future PHEVs come out with higher capacity batteries I think EREV cars will become more common. If you have enough battery power there isn't much point in starting up and blending in the ICE when there is still juice left in the pack.EREV communicates nothing useful since there are always further descriptions and caveats needed, and what you consider to qualify as "EREV" someone else may not, and vise versa, since it's not a real term. You claim the Ford is not an "EREV" since it doesn't meet your definition, which seems only to apply to the Volt, and maybe the ELR I guess. Just look at all your arguments as to why one vehicle is an EREV but another is not. The hair splitting is subjective. Enthusiasts can argue the details but it only fosters confusion amongst the general public.
I agree that future plug in hybrids will have more battery only range and performance, and that logical progression nullifies any need to create a new label for them. The Volt/Ampera really does seem to be the best of the current crop, the i3 could have been but it's crippled by poor styling, an ICE that seems only to provide something of a limp home mode so it's not a great hybrid, and too limited range in it's pure EV form so it doesn't advance EV technology.
The ELR is not an EREV because it does not get "full performance" with the ICE off (0-60 time is lower). The Fisker is also not an EREV for the same reason (0-60 and top speed is lower in EV mode).Huh? How so? The ELR is just a Volt with less conservative software controls, a new body shell, and lots of fancy interior materials and accessories. I'm not aware that it's EREV-ness is any different.
So as long as they have the default on "EV now" it's automatically an EREV by your definition?Optional driving mode buttons are irrelevant -- if you push a button that purposefully starts the engine ("Hold mode") that shouldn't detract from whether the default operation of the car complies with EREV.
Non-EREV cars may start the gas engine at all times of the year in their default driving mode under common and typical driving conditions or have unusually limited capabilities in an optional "EV now" mode.
That's true for a Volt as well -- performance is a bit better at speeds above 45 mph or so in hybrid mode with the engine running. So?The ELR is not an EREV because it does not get "full performance" with the ICE off (0-60 time is lower). The Fisker is also not an EREV for the same reason (0-60 and top speed is lower in EV mode).
The E-REV is unique from a PHEV in that the vehicle, battery and propulsion system are sized such that the engine never is required for operation of the vehicle when energy is available from the battery....As a full-performance battery electric vehicle, the battery, motor, and power electronics must be sized for the full capability of the vehicle.
While the goal is clearly to avoid starting the engine while charge remains in the battery, the paper's more specific definition is relative to general PHEV's needing to start the engine during EPA test cycles (and beyond those power requirements during typical use of the vehicle):GM's definition (as opposed to colloquial definitions which vary depending on who you ask) has the following two criteria:
It must be a "full-performance" EV when the ICE is off.
The ICE must never turn on until the battery is depleted.
http://www.media.gm.com/content/dam/Media/microsites/product/volt/docs/paper.pdf
An E-REV does not need to start the engine for speed or power demands from the driver...
We haven't seen all the details of the i3's range extension behavior yet but it's a certainty that the engine will start up occasionally for maintenance purposes (lubrication, burn off stale fuel, etc.) before the battery is depleted. I guess you aren't counting that exception. The only presumably remaining difference from the i3 is the Volt's behavior of occasionally running the engine at temperatures under 15F (-10C) to use the waste heat to assist in cabin heating.The i3 REx is the only car that meets both criteria with no exceptions (and it makes sense given it started as a BEV with the "range extender" added afterwards). The Volt satisfies the first but not the second (unless you ignore exceptions).
GM showed off the concept Volt at the Detroit Auto Show in January 2007 and committed to build it by the end of 2007. This SAE paper was published in 2008. The non-seriesness of the Volt's range extender was first revealed in September 2010.Originally GM's definition was much simpler: EREV = series PHEV, but they couldn't use that definition after they changed the Volt's design.
The Ford Energi models when switched into "EV now" mode are getting close to what I would consider EREV but subjective experience reported by owners at Energi forum sites indicate that acceleration power is weak at highway speeds. I wonder how capable it is at maintaining a US06 cycle on steeper uphill grades.So as long as they have the default on "EV now" it's automatically an EREV by your definition?
