The ELR is not an EREV because it does not get "full performance" with the ICE off (0-60 time is lower). The Fisker is also not an EREV for the same reason (0-60 and top speed is lower in EV mode).
See how clear the term EREV makes everything? :wink:
How can you not see the contradiction in your statements? Simply put, the Volt needed to have both electric drive and an ICE for you to purchase it. Missing either you would not have bought it.......
.....I'm seeing the entire picture and you're ignoring half of it. Volt owners seem to suffer from "ICE blindness".
Please show me where the GM SAE paper states or even implies this interpretation. I didn't see that anywhere but maybe I missed it.I interpret "full performance in EV mode" to be equal to or greater than hybrid mode performance. I think this interpretation is what the GM authors of the SAE paper you linked intended, and it makes the EREV distinction more useful.
Do you have a source for this claim?While Jeff N points out that the Volt's EV and hybrid modes are not exactly equal, they are never more than 1-4 horsepower different throughout the entire 0-100 mph speed range, and both are limited to 100 mph. This is as close as we can expect the calibration engineers to get.
2011 Volt CD v. CS Mode
ACCELERATION TO MPH
0-30 3.0 3.2
0-40 4.5 4.6
0-50 6.4 6.4
0-60 8.8 8.7
0-70 11.9 11.3
0-80 16.0 14.5
0-90 21.3 18.3
0-100 29.8 23.0
PASSING, 45-65 MPH
4.9; 4.5
No I am fully aware that what differentiates the Volt is it's use of both technologies. That makes it different than an ICE and different than an EV. It makes it a plug in hybrid. We both agree on that, the only difference is you and others think it needs another distinguishing term beyond that, though no one seems to agree about what exactly that term should cover. That's the problem with making up a term for marketing purposes. GM created a term that only fit it's vehicle. Think of it this way, Toyota could take the original Prius hybrid, not change the design one bit, but increase the pack size and electric motor sizes, such that it has full performance in EV only mode, even if it only went 10 miles or so on electricity, and it meets the criteria for EREV. They could also build the same vehicle but give it 60 miles of electric range but maybe the ICE would come on above 80 when you floor it or something. That vehicle, certainly capable of more real world electric only use, would fail the EREV criteria. Or not, depending on who is interpreting it at the moment.I think we both see the entire picture. Surely you realize that I know the Volt is a PHEV with a ICE. I am not ignoring it. However if I am, the maybe you are suffering from "EV blindness" by occasionally ignoring that the Volt's EV capabilities are what differentiate it from most other cars.
Sure, but you're also buying it because of the ICE capabilities, and the fact that one plug in hybrid might run its ICE a bit more under different conditions than another plug in hybrid doesn't warrant a special term, especially when an arguably better vehicle with more EV only range could be built that failed to meet the specific criteria. Since Tesla built an EV with more range and better performance than any other EV they could have come up with a special name for that as well but didn't see the need.The EV capabilities are why people buy Volts instead of pure ICE cars and non-plugin HEVs. This is where most people are coming from, myself included.
But not as clear as:
Does it have an internal combustion engine: Yes -- Does it have an electric motor for propulsion: No -- Does it plug in: No= ICE
Does it have an internal combustion engine: Yes -- Does it have an electric motor for propulsion: Yes -- Does it plug in: No = HYBRID
Does it have an internal combustion engine: Yes -- Does it have an electric motor for propulsion: Yes -- Does it plug in: Yes = PLUGIN HYBRID
Does it have an internal combustion engine: No -- Does it have an electric motor for propulsion: Yes -- Does it plug in: Yes = BEV
You forgot one....
Does it have an internal combustion engine: Yes -- Does it have an electric motor for propulsion that provides full performance comparable to other vehicles in its class without starting the ICE: Yes -- Does it plug in: Yes = EXTENDED RANGE ELECTRIC VEHICLE
You forgot another...You forgot one....
That is just a marketing ploy to confuse people. It's a plug in hybrid, and still has a dirty gas engine.
So Plugin Prius == BMW i3 with range extender
It's just a "marketing ploy" to distinguish between them?
By my reading, the GM engineers did not intend the EREV "full performance" in battery mode to be defined in any way at all relative to extended range performance.
I see no effort by GM engineers to force hybrid (CS) mode to be artificially limited into having the same exact performance as battery depletion mode. What would be the motivation for doing that other than someone's idea of ideological purity? The Volt's motors are capable of higher performance than the 16 (or 16.5) kWh pack can provide so the car gets a bit more power when the battery is supplemented by the engine and generator.
Here's is data from MotorTrend comparing the 2011 Volt in battery mode versus hybrid mode (CD vs. CS):
Code:2011 Volt CD v. CS Mode ACCELERATION TO MPH 0-30 3.0 3.2 0-40 4.5 4.6 0-50 6.4 6.4 0-60 8.8 8.7 0-70 11.9 11.3 0-80 16.0 14.5 0-90 21.3 18.3 0-100 29.8 23.0 PASSING, 45-65 MPH 4.9; 4.5
So you would have bought the Volt if it didn't have the ICE?I was just stating that I did not buy my Volt for its ICE capabilities, but for its EV capabilities instead. I am not going through that again, but you can reread our posts above or PM me if you wish.
GSP
You do know that there have been standard definitions of serial hybrid and parallel hybrid right? If you want to drill down deeper then plug-in hybrid, you can use one of those.
Sure we do. I see tables of performance numbers and specification attributes all the time in car magazines and on manufacturer's websites. Those cars are all conventional ICE machines so their engines run all of the time from beginning to end. I see table entries for 0-60 mph, 45-65 mph, 1/4 mile time and final speed, etc.Exactly, we don't reclassify different ICE vehicles because of how they perform. Yugo, Corvette, Accord, all ICE's.
