Ok bear with me, looking for advice from the group. I have a M3 LR on order due to be delivered in Feb. I own a condo at the beach in NC. We rent it out all summer and use it a little in the off season. The closest superchargers are a hour away (Myrtle Beach and Wilmington). I have access to a 5-15 outlet but 3mi/hr of charging does not excite me. It is a multi unit building so the HOA controls the outside of the building. I will need to ask them if I want to run any kind of electrical on the outside of the building (thinking maybe a 14-50 if the panel can support it). The other concern with this approach is that the salt air corrodes everything metal (including outlets without tight covers over them).
An alternative I am considering is that the dryer outlet is a 14-30. I can get a 50ft extension and the portable charger should be enough distance to make it to the car to get about 22mi/hr charging.
Has anyone delt with an HOA when modifying the electrical for a multi-unit building and did that work out?
Has anyone tried the dryer-extension approach?
Any additional advice for a corrosive environment?
Thank you in advance.
