Quick 220 system?
Discussion in 'Model X: Battery & Charging' started by pw1388, Jan 6, 2017.
  1. pw1388
    pw1388 Member
    Honolulu
  2. bikeandsail
    bikeandsail Member
    United States, NE Ohio
    I bought one and tested it, have not actually used it while traveling. 6 to 7 mph beats 3 but still only good in an emergency for me. If you don't drive much might work. You need to 2 separate circuits out of phase to make it work and no GFI, pretty big limitations for most.
  3. BerTX
    BerTX Supporting Member
    Texas/Washington
    The two 120v outlets you use must be out of phase from each other. Is that the case in your garage? Do you have two separate 120v outlets on two separate breakers in your garage? If not, it won't work.
  4. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    Here is some info:
  5. Rocky_H
    Rocky_H Active Member
    Boise, ID
    I bought one, because early on I wanted to be very prepared, and I was willing to be kind of adventurous when there were no Superchargers anywhere near me. I've never actually had an opportunity to use the Quick220. The limitations make it difficult to use conveniently.
    Yes, it needs two different 120V circuits on different phases. OK, that's difficult enough, but the "no GFI" requirement is almost the tougher one. Garage outlets in a room that has a water heater are usually required by code to be GFI because they may be subject to water. When I was testing mine out, I tried a garage outlet and one in the house, and found it didn't work. I was then surprised when a day or two later, I opened up the chest freezer and found that it was not very cold, and the stuff was on the verge of thawing because the GFI breaker had tripped--close call.
    So, since garage outlets are usually not usable, you have to find two circuits in the house, and then run extension cords through the place, and then out to the garage or driveway where the car is, etc. etc. and it's a big pain in the butt. And to have the most compatibility of many potential outlets, I chose the model for 15A circuits. That yields a 6-15 output, and Tesla does now sell a 6-15 adapter for the UMC.
    So yeah, this stuff can work, but it's so cumbersome that it's hard to justify a use case for it. If you really want to charge at a place that's not set up for it, try for a dryer outlet, and if that's not available, I'd say just go for a regular 120V outlet outside or in the garage--way simpler. Besides, on Plugshare or Allstays or something there is usually at least a 14-50 or J1772 you can find somewhere.
  6. K-MTG
    Irvine, CA
    My house was recently built but I found that each of my garage door openers were on a non-GFI independent 20 amp circuit which was perfect for the quick220
  7. Rocky_H
    Boise, ID
    Oh, that is a pretty interesting case. They are mounted on the ceiling, right? That is probably why they are exempt from the GFI/water requirement.
  8. K-MTG
    Irvine, CA
    Yup on the ceiling, I also got another one mounted near the attic access in the ceiling of the garage
  9. BerTX
    Texas/Washington
    They still need to be on different phases, but that would just involve moving the breaker in the box. Be sure they are not on GFCI breakers. Also, don't operate the garage door while charging -- .best to unplug them
  10. K-MTG
    Irvine, CA
    Nope, no GFI breakers! My garage door opener uses a max of 4 amps and the quick220 pulls 12 amps and the circuit is rated for 20 amps.
  11. BerTX
    Texas/Washington
    Oops, sorry. I thought you were the OP who was asking for opinions. Now I realize you are not, and that you already know.
  12. carteriii
    carteriii Member
    Downers Grove, IL
    For what it's worth, there is a competitor to Quick 220 that I bought and I have used. The model I got is from Steam Brite: Power Joiner Step Up Inverter Takes Dual 20 Amp 115 Volt Outlets to Allow 230 Volt 3 Wire 20 Amp Use
    The reason i went with Steam Brite is because I wanted a different connector than Quick 200 provides. In my case, I got an L14-30R because I already have an L14-30 extension cable for use with a portable generator (no I'm not using the generator with my Tesla). The Steam Brite comes with two much longer extension cables to plug into the individual outlets which may be further away from each other.
    If you search on their site for just "power joiner step up inverter", you'll see a list with different connectors. This link should do that for you: Steambrite Supply Advanced Search: power joiner step up inverter
  13. TonyWilliams
    TonyWilliams Active Member
    San Diego - Tesla powered Rav4 EV
    Quick 220 is actually patended. I'm confident that when the company that makes Quick 220 is made aware of this unit, they won't be producing it anymore.
    Also using a 30 amp receptacle would probably not be normal or even safe, since in nearly every instance, 120 V outlets are on a 15 amp breaker.
  14. carteriii
    carteriii Member
    Downers Grove, IL
    You are absolutely correct to note that, but to be fair your comment isn't unique to this situation. Almost everyone using the Tesla 14-50 plug with adapters to plug into 30A drier plugs (or anything less than 50A) needs to manually dial down the current to 80% of the supply (e.g. 12A on a 15A breaker). That's what I do. To anyone else reading this thread who isn't comfortable with electrical knowledge, the general warning is that you cannot safely use most ANY adapter from someone other than Tesla without dialing down the current. Even the adapters commonly used and from reputable places require manually dialing down the current.
  15. carteriii
    carteriii Member
    Downers Grove, IL
    FWIW, I found mention of Quick 220's original patent on their website at Quick 220 Systems - The Company
    Looks like it issued November 2, 1999, just over 17 years ago. They may or may not have something newer.
  16. Cellsaver
    Cellsaver Member
    Cincinnati Ohio
    Thanks to some advice from guys on the forums here, I am having a 20 amp/120V receptacle in my garage converted to a 20amp/240V NEMA 6-20 receptacle. I'm having an electrician do it but it sounds pretty easy, you use existing wiring just have to make sure nothing else is on the circuit.
    Then you can either buy the Tesla NEMA 6-15 adapter, or you can get the Tesla 5-20 adapter and make a 5-20 to 6-20 cable to take max advantage of your amps. You don't have to dial down your amps either way the UMC will take care of it.
  17. TonyWilliams
    You're simply reinforcing my caution. I don't recommend putting a Nemo 14-50 plug through an adapter and do anything except a 50 amp or higher rated outlet.
    In addition, there are literally thousands of electric vehicles that don't have the option to manually's spin down the amps on the dash instrument.
    So, to reiterate, I absolutely do not recommend building adapters are using plugs that are unsafe and could overload the circuit.
  18. Mike M
    Mike M Member
    Boulder, CO
    I'm a little confused (and not an electrician). I have a 14/50 outlet that I plug our Ford C-Max PHEV into (Tesla has a dedicated wall charger). Its on a 30 amp circuit with a clipper creek level 2 J1772 power station plugged in. I've never had an issue with using this setup. If the vehicle draws to much power, isn't that the point of the circuit breaker to trip on an overload? I guess I'm a little confused how a device can "pull more power" than what the circuit breaker allows to be delivered.
  19. davewill
    davewill Member
    San Diego, CA, US
    I'm guessing your ClipperCreek is designed for a 30a circuit and limited the current, otherwise you would have overloaded the circuit. A circuit breaker is a safety device in case of an accidental overload or short. It's a bad idea to purposely create a situation where an overload is possible. That said, I don't think the adapters are so bad for occasional use where the user can carefully check that the car is set to a safe charging level. I draw the line at daily/permanent use where the car might forget it's charge level setting or the unwary might plug a car in.
  20. Mike M
    Mike M Member
    Boulder, CO
    Thank you for clarifying @davewill !
    BTW... You are right, I just checked, the Clipper Creek only pulls 16 Amps.
