My point is its NOT due to faulty measurement. You can't get 121+ MPH from a P90DL no matter how you measure.….
Since they're reporting 121+ MPH at the exit it can only mean they're using ICE correction factors....They either corrected for ICE or Tesla gave them a ringer
I…121 MPH is simply not possible on a P90D without it either being a ringer or having a massive tail wind.
…121 MPH is not remotely achievable under either standard unless you have a strong tail wind or have a ringer.
Well now, hold your horses. (no pun intended)
"not possible", "not remotely achievable", that's pretty strong. I don’t know if I’m ready to believe that it’s “not remotely achievable” unless it’s a ringer or you have a strong tailwind.
I believe that the 121 mph figure comes from the C&D tested vehicle.
Yes, here it is:
2015 Tesla Model S P90D - Instrumented Test
First off, there is the Vbox video from forum member Burt Reynolds showing the 119.1 mph speed. I linked to it earlier
Then if you go to the drag times site, using the arrows will allow you to arrange all of the metrics in either ascending or descending order.
Fast Tesla Model-Ss 1/4 Mile 0-60 Drag Racing - DragTimes.com
Arranging the drag strip obtained trap speeds in order, we have George Dodworth at 118.95.
George also shows another time slip indicating a trap speed of 118.76 mph.
Next up is fiksgt with a trap speed of 118.58 mph.
All three of these are very close to that Vbox 119.1.
And they're doing this on a prepped drag strip with VHT on it, and possibly more rolling resistance than on an unprepared surface or a public road as was Burt's case.
So their's are actual drag strip trap speeds, measured starting 66ft from the finish line, and not Vbox speeds.
So the Vbox result of 119.1 mph we see in the video Burt posted up, seems ok, and is just 0.15 mph over the best trap speed we've seen reported on a drag strip, 0.34 mph over the second best, and 0.52 mph over the third best.
Now, how do Vbox calculated trap speeds compare with actual drag strip trap speeds?
How does a Vbox maximum speed at 1320’ compare to actual drag strip trap speeds?
I think that we agreed that it would be faster, but don’t know how much faster.
At any rate, looking at the above examples, we’re talking a difference of 2 mph or so in order for one of those three gentlemen to reach that 121 mph mark which you say above is “not remotely achievable unless you have a strong tailwind or a ringer."
I’m not quite ready to say that just yet, and here’s why:
The C&D car which has the “unattainable” 121 mph speed you're discussing in your posts above, was indicated in the article to have been a stripped down or low optioned, no sunroof model.
However, each of the three examples above were well optioned cars, and with sunroofs, including Burt Reynold’s car which the Vbox info came from. Burt's 119.1 Vbox reading, puts him just 1.9 mph off of the 121 mph mark. His thread is in here and I can link to if if need be.
So now, I’m trying to see, how it’s "simply not possible" that a lighter car, such as the one used by C&D, could end up being 2 mph faster, (actually just 1.9 mph in Burt's case) than a heavier car.
Especially when comparing some of the heavier car's authentic trap speed, to the lighter car's likely 1320' vMax.
The roughly 2 mph difference between, the C&D car and the trap speed drag strip results we have from drag times, and we've agreed that drag strip trap speeds are typically slower than 1320' vMax, could be the result of multiple different possibilities, aside from “ringers”, “correction factors” and “tailwinds”.
And based on that, it becomes even harder to holler “ringer” when looking at the few results that we have thus far.
The 121 mph speed then to me, is feasible based on what we have seen in owner driven cars.
However the 122.7 mph speed is more of a mystery and at this point, I would not even hazard a guess.
