I was hoping for a better-insulated pack or some such (this area was an area of feedback I gave Tesla very early on in Model S development).
Given the massive surface area on the bottom of the car, I'd be surprised if it were well insulated.
Why? Insulation is cheap and it wouldn't have to be very thick to do a lot of good.
I've asked ownership for information on what happens when it gets even colder (e.g. 0F), about warming while plugged in, plus general comments about having regen limited or removed for 5 months of the year every day after work not being ideal.
It's only 4" thick, and there's a lot of surface area. There isn't a lot of room for insulation. It's bound to lose some heat.
I hope Tesla does not decide to warm the battery pack whenever the car is plugged in, that would waste lots of energy. Making it easy to charge just before driving is a much better solution. This doesn't help if the car isn't plugged in, but in that case spending energy to improve regen makes no sense either, IMO.
It absolutely does. That was my point. The Roadster automatically limits regen when traction is limited and so you cannot always count on full regen all the time as it can be limited for a variety of reasons. When you're coming up to a stop sign or whatever you lift off the accelerator and cover the brake. If the car doesn't slow as quickly as you'd like under regen then you press the brake pedal. It's really intuitive when you're doing it.I would expect TC to override regen when losing traction. Imagine going into a slide/spin because of regen!
I think that actually only happens below freezing. However there is another reason to limit regen at temps above freezing, cell voltage. Colder temps mean the internal cell resistance is higher, so current going into the cell will drive the voltage higher than when it's warm, and the higher voltage can cause electrolyte solvent breakdown.The chemistry changes when the battery is cold. The lithium tends to precipitate in metal form on one of the electrodes, I think. Anyway, the batteries will degrade rapidly if charged when very cold.
That's a good point. On the Roadster there's a light on the dash that's very obvious. When I say it for the first time I stopped, pulled out the manual, and read about it. After that it wasn't a surprise. Seems like it's much more subtle in Model S.I take it for granted that this is good engineering by Tesla given it probably preserves energy and more importantly battery life (most critical given battery costs).
My biggest issue is the lack of communication/education on how this works. My wife was very freaked out by the non-trivial change in driving dynamics as she abruptly lost regen one cold morning and then just as abruptly gained it back as the pack warmed. You want a car to drive consistently and if it can't, give you a clear indication when it changes (we eventually figured out what the dotted line means, but it wasn't immediately obvious given no previous communication on the topic or experience with a roadster).
Needs to be messaged clearly by the delivery specialists and probably should give a clearer message at start-up on one of the screens when regen is limited.
... My wife was very freaked out by the non-trivial change in driving dynamics as she abruptly lost regen one cold morning and then just as abruptly gained it back as the pack warmed. You want a car to drive consistently and if it can't, give you a clear indication when it changes (we eventually figured out what the dotted line means, but it wasn't immediately obvious given no previous communication on the topic or experience with a roadster).
I think this is an extremely important real and perceived safety issue and should be addressed. Tesla Engineers just need to fix it.
While probably wishful thinking, it seems an ideal solution would be to switch the regen from batteries to some sort of resistive heating element in the HVAC system when the batteries can't take the charge due to cold. It seems a waste to throw the energy away as brake heat, and it would resolve the issue of regen braking characteristics changing.
60kW is a lot of energy just to dump somewhere other than the battery charging circuit.
60kW is a lot of energy just to dump somewhere other than the battery charging circuit... Don't think of it as wasted energy on a cold morning, thinking of it as giving your brakes the necessary exercise they need to prevent glazing.
No kidding. To put this in perspective, the average electric baseboard heater is one kilowatt. You could dissipate it in a resistive heater but it would need massive heat sinking or it would go up in flames. You'd probably have to distribute it around the battery pack to take advantage of its cooling. Wouldn't be worth all the extra weight and complexity.
