I realize OP isn't an engineer, but mis-reading mV vs. V on a meter is disconcerting. Please be careful and understand what you are attaching the probes to.
Even engineers and scientists make unit conversion mistakes more often than you'd think.
If you get a chance to pull the HVJB, the red-circled device with 4 terminals has never been identified--thinking it might be some sort of thermal protection?
Once the DU is out of the cradle it can probably be lifted by a couple of strong guys. Definitely too heavy for one person. Lots of iron in there! If you have access to an engine hoist or similar, that's best.Who's better than you?
After I remove the chargers I'll get to that. There is just so much to do!! (MCU, DU, HV BATT etc. etc.) I'm pretty sure the DU is toast, This car was apparently sitting in not just regular saltwater but SUPER SALTWATER
What are we looking at for weight of the DU? Can it be lifted onto a workbench?
I don't think that I really understand the long-term strategy here. Clearly making this car functional will require a number of replacement parts that Tesla won't sell to anybody. How can this work?
Is the idea to find a parts car that was totaled due to structural/cosmetic damage and use its circuitry? If so, it seems like using *this* car's body to repair *that* car's damage might be easier and more reliable than trying to replace all these electronics.
Still, it makes for a really interesting thread. Good luck!
Engineer: I'll never fault anyone for Effective Uses Of A Forklift, but I'm wondering:
didn't Tesla demonstrate that their Quick-Change of the battery pack involved nothing more than a zip-zip-zip of just four bolts, then drop-and-swap? Oh, and quick-coupler releases of the coolant fluid lines.
Toward the beginning of this thread, OP said his Tesla friend told him that before the car died in the drink, it threw 47 codes, several of which indicate water in the pack. It's shot, and can't be opened without irreversible damage.
I guess I didn't look carefully after that forkpornpic.....:redface:26 bolts, not including the 8 fasteners on the shear plates and the battery battery shields. I didn't advise Btr to drop his pack, but rather the drive unit. His pack may well be fine and need not be unsealed, but the drive unit is most likely full of saltwater. The pack does have quick-release for all connections, but the DU does not.
Well Jesus then, wk057 sure made a mess of it in that case.Packs can be opened and resealed without irreversible damage. I have done it.
With the right tools you can remove the top intact. If you don't care because you just want to get the modules (like in Wk's case), then sure, just rip it off.
yobigd20, we've all told him. That's what makes this so interesting. There are several guys who've bought salvage cars for uneconomic money and are now silently suffering. I watched one go today with a bent frame for ridiculous money. I bothered to go there and check it out, but Dude who bought it, didn't. He is in for an awful surprise.
