Pull the glovebox, the passenger knee airbag and the crossmember below the glovebox and the heater slides right out. You can unsnap the cover and take off the 2 HV wires, but check voltage first. Tape them up really good or disconnect the other end (DC-DC converter in the passenger wheel well behind the splash cover).not much progress last night, but for the heck of it I decided to check the fuses, turns out of all the fuses only one is blown. Its the 30A fuse that handles the exterior and interior lighting... interesting
- - - Updated - - -
one of the codes thrown by the car was the "service heater" code. It looks like the water line reached that as well. *SIGH* this does not look pleasant to remove. I'd like to avoid pulling the dash if possible.
I found general corrosion in here and damage to one thermistor on one of my flood cars.
The battery is an integral stress member of the chassis, that's why it is bolted in so well. It will stay up in the car with only 4 bolts, so leaving all the rocker bolts in is more than adequate for static loads, just don't drive the car like that.
It should be possible to slide the battery out sideways, but you will need 4 jacks. Yes, the suspension crossmember (subframe) can support the car, especially w/o the weight of the pack!
You will need to rather evenly jack up all 4 corners if you are going for the side exit. If you drop the DU first and disengage the 2 rapidmate connectors in the back, you could do a 2-jack tilt to the passenger side and bring the pack out the driver's side, but don't do it the other way, or you'll likely break the front coolant quick-connects.
If I were you, I'd pull the DU first, get it out of the way. You absolutely need to do this anyway, then the pack will be easier.
The first thing I did on my flood cars is pull the interior, I gutted it bare. Then the DU.
Unfortunately there is a thick pad on the firewall behind the dash that is a nice sponge. It must be removed in your car or it's stinky swamp mold city. The sooner the better. The bad news is it's hard to take out. If you don't want to discharge the A/C system, you have to cut it, but it is do-able. Until then your car will always be a stink humid mess!
