Firehuntah
Everyone using the 15 mm spacers with the stock 18" wheels, no problems with the wheel studs being too long?
I measured on my Model 3 today, the wheel studs stick out about 26,5 mm and the hollow space inside of the 18" wheels is only about 11 mm. So if you go with the 15 mm spacer that stud should stick out 11,5 mm which is just a little bit too much? Did you have to cut the studs or are the studs on the European Model 3's perhaps a bit longer? I just don't see how this would fit without having to modify or having to go with 20 mm.
Now I mainly want to get spacers for my new wheels and they have a lot more space inside, but as I'm using the original 18" as a winter set it'd be nice if I could use the same spacers for those wheels as well without having to modify anything.
