israndy
Supercharger Hunter
Nice, but I wish the images were labelled or the words I don't know were linked to images, what's a Right Side Locking Tab?I went with plan C with my 2021 Stripped PLC ECU 4 (1537264-80-B) -> (1537264-00-B):
So For Example:
Find the clip inside the upper left corner of the trunk, inside from the brake light
Remove the clip with a flat blade or an interior clip removal tool
Don't let the plastic interior fall down as you may break it's other retainer clip
Pull down the FELT liner to reveal the interior light mounted on the inside
Unplug the light
Pull down the liner with force to reveal the ECU location
Remove the black bolt with a 10mm socket and with your fingers to be sure you don't drop it into the interior below
Unplug each of the connectors and remove the ECU, note there are alignment fingers in the metal surface to prevent the ECU from spinning on it's bolt. After plugging the connectors into he NEW ECU be sure to test it before you start re-installing everything. Then simply put everything back in the reverse order you removed them above. The plastic clip (see photo above) can be disassembled into two parts, the hole part should be threaded thru the two liner pieces and into the metal body of the car and then the plunger part inserted into the hole part to lock it in place.
Be sure the felt liner is under the rubber seal and that the seal is fully seated when install is complete
Also make sure the felt liner is inserted into the plastic liner across the top of the trunk
This is just my guess as to the order of the photos and the labelling but something like this should be moved to the first post in this Wiki. Would also be nice to include photos of removing the entire connector that is the 'bundle of wires and resistors', heck even a photo shoot of putting that connector together would be useful.
Perhaps that's my thing to do with today as that's the stage of installation I am at. Is this project on anyone else's todo list this weekend?
