MFrunkerOG
Yes did that.Look at the model S post for the same. It’s the same command.
I went through all 12 pages here but couldnt find the service shel commands to use . MY headlights are in and like a genius, I installed them before testing...
Help me with the service commands please? My toolbox 3 access and connection to the car are just great.
gw-diag SET_CONFIG_DATA 0 28 2
reboot-gateway
Yea I found that. Thanks.Code:gw-diag SET_CONFIG_DATA 0 28 2 reboot-gateway
Yeah it’s definitely a bit of a pain to find a truly perpendicular wall. For my vertical aim was able to eyeball with reasonable accuracy, but horizontal I was way off without the wallYea I found that. Thanks.
All done now! The headlight adjustment is a bitch though!. Getting the car perpendicular to the wall takes some doin!
I’d suggest skimming through all previous pages here. It has all the info.Hello everyone, i have been following the thread and i would like to retrofit my model x with matrix headlights , could you please help me i have some questions.i have a 2023 model x build January 2023, and i haven't done any retrofits prior .
1.do i need to remove the front bumper to replace the headlight?
2.where do i find the ethernet port?
3.what parts should i order along with headlights!!
Thanks for the update , after looking at upcoming software update for matrix headlights i have placed the order same ebay friend !! Have to order adapter now.Yes
Above charging pad
You need an adapter. Sold on ebay or a website if you skim through this thread. Same seller. (ebay search: Model X Matrix headlights)
They also need to be programmed. Read the thread, lots of info.
They have confirmed to me that they are "seconds" but I have been unable to find out what was wrong with them. Mine seem to work fine but since I came from SAE lights I probably would not recognize the deficiency.My headlights came in today from our ebay friend. he accepted an offer $100 below his asking price and the headlights were in fact new. Not sure where hes getting them from. Tesla quoted an insane price.
Just looked at the top of your right headlight. Looks a bit sunken in against the side panel/ fender. That means it’s pointing up. Jiggle it level to the panels?Installed my matrix headlights last night and it was a success besides one problem.
Has anyone encounter the problem with the right/ passenger side headlight not adjusting the same to the left/drivers side? The right side doesn’t adjust as low as to the left side when adjusting to the lowest setting for both headlights. See picture below with both headlights set at the lowest settings. Also adjusting to the highest setting on both headlights, left doesn’t go as high as the right side.
Yes. Once the headlights are set as global headlights in the configuration, the adjust headlights routine appears in the service window.Can anyone confirm if we need to follow this for the physical aiming?
Model X Service Manual | Tesla
Correction code 17400160 0.18 NOTE: Unless otherwise explicitly stated in the procedure, the above correction code and FRT reflect all of the work required to perform this procedure, including the linked procedures. Do not stack correction codes unless explicitly told to do so. NOTE: See Flat...service.tesla.com
Or are the matrix full aiming done on the screen? I dont recall seeing adjusters on the lights themselves like the old ones.
A day is more than enough. Just don’t buy it until your lights are physically in your hands and your old lights are out don’t trust FedEx!Can someone help.
Is it good to buy one day subscription for toolbox and update the code !!
Or ask someone to remote and make him update the configuration? If so could someone DM me contact.
Sure thanks !! Both adapter and light gonna arrive this week hopefully.A day is more than enough. Just don’t buy it until your lights are physically in your hands and your old lights are out don’t trust FedEx!
Don’t ask me how I know!
Which revision did you receive?My headlights came in today , so far good condition no visible scratches !! Waiting for adapter to come in today !!
