Retrofit to matrix (global) headlights?
It’s been done on 3/Y and the headlight itself is a direct swap but it requires someone with elevated toolbox access to change the gateway configuration in order for it to work. The refreshed S/X is probably similar but don’t quote me on that.
Reactions: MSJack
Yeah I read about the 3/Ys but wanted to check if that’s the case for Model X too.
I guess the hard part is changing the gateway config.
Umm what was the process?
Insta link just shows blinking turn signal
If I had posted a picture of it installed, can’t really tell it’s the matrix headlights.
The process :
1. Install matrix ligjt
2. Requires 4 wire to 3 wire harness
3. Update your config file which requires some hardware is you don’t have Ethernet port in your car
Reactions: skytom88
I've been told by my Tesla contact that you need the 1000.
One of these may be of interest to you
Curiously being sold by a liquidator in Fremont..
The first link seems to use an ix industrial connector instead of a typical RJ45, but those ixindustrial to RJ45 cables are cheap enough. You would also need to make or buy a matenet to H-MTD connector to connect to the car.
Just to be clear, model X should not require headlight adapters. The connectors and pinouts are the same. Model S is the oddball there.
Still need the gateway configuration update though
The connector on my non-matrix didn’t match the matrix light connector. So an adaptor harness was required (6 pin to 3 pin). I believe it’s same for Mx refresh.
6 pin non-matrix
3 pin adaptor
