My late 2017 S75D originally showed 203 miles rated range at 80% charge. After about 9000 miles this has dropped to 200. Is this normal?
Better than normal even.My late 2017 S75D originally showed 203 miles rated range at 80% charge. After about 9000 miles this has dropped to 200. Is this normal?
The guestimator has more sample points to approximate mileage based on your driving habits. That 200 miles has some errors around +-10% depending on where you live.
If you now moved to a new area where it's always flat and drive 9203 miles, that 80% at 200 miles will be 220 or 230. Then, also the temperature also plays a huge part in the guestimator.
No. Wrong. The displayed rated range has nothing to do with your driving habits. Nothing.The guestimator has more sample points to approximate mileage based on your driving habits. That 200 miles has some errors around +-10% depending on where you live.
This is correct. Don't listen to the Service Center personnel in this case. They will tell you it is based on driving habits, thus putting the blame on the owner instead of the car. You could drive another 10,000 miles at 25 mph and I promise your rated range would not miraculously jump up to a higher level even though your Wh/mi was at 120 (although I'm not volunteering to test this).No. Wrong. The displayed rated range has nothing to do with your driving habits. Nothing.
For another data point, my 80% is at 193 miles with 45,000 miles.
I can't bet, as I have no idea on what you are asking me to wager. Nor what the voltage and capacity of a battery has to do with my driving habits.So, you're saying if I take a 3.3 volt battery and a 3.3 volt battery from another area (both batteries rate 3300 mah), it will hold the same capacity?
Wonderingi if that is true in reality. I propose a bet.
I had this epiphany also, and realized that Superchargers were getting closer together faster than my battery degraded, so no more concern.As long as I can make it from supercharger to supercharger when travelling, I have all the battery I need.
