We may be entering the 5th wave, as seen best on the 30-minute chart. Possibly sub-wave 3 of the 5th wave.
The 30-minute chart seems to be the most obvious depiction of the triangle. You have 5 waves within the triangle and after the 5th it broke out and is "thrusting" upward completing 5 subwaves. This is the textbook Elliott Wave Theory. So unless I'm reading this all wrong this has to be a B wave because it's impossible to be a 4th wave. If this is true then this rally is just a part of a larger corrective pattern that has yet to complete and will likely drag on for some time.
If we can pass 200 I would think 202 would get sticky. 200.11 is the 38.2% fib retracement from the July 19th, 2023 high. 202.6 is the close of the gap made on Mar 4th. 201.97 is the 50% fib retracement from the last wave down and just so happens to lay at the top of this channel. We haven't seen any divergence yet on the higher time frames (30min & 1hr) which is normal before the 5th wave. But now, if we are entering the 5th sub-wave, we should start to see some RSI divergence on the 30-minute and 1-hour chart near these key levels.
