I trust this developer, MaaDoTaa. This is the same developer (and also a Tesla owner) that created the "Stats" app and it is awesome.
Unfortunately, the SanDisk required is $50. This makes it a no-go for me.
I paid $35 for the 64gb
Not sure what "individual" you refer. I was asking the person who made the quote about not wanting to buy a $50 USB stick. You are answering for someone else whom may or may not agree with you.A USB stick isn't a car. This individual thinks a car is worth tens of thousands of dollars, but that a USB stick isn't worth $50. No skin off my nose.
I was wondering the same thing, but then see that it is a wifi USB stick and the app probably requires Wifi to work. And I speculate that the app isn't going to communicate with it if the USB stick isn't on Wifi like at home or work or a public wifi.I've got a 256GB SSD. Wish this would work with that instead of requiring the SanDisk. I wonder why it will only work with the SanDisk?
That makes sense, but seems odd to limit the functionality like that. But I'm not an App developer, so what do i know?I was wondering the same thing, but then see that it is a wifi USB stick and the app probably requires Wifi to work. And I speculate that the app isn't going to communicate with it if the USB stick isn't on Wifi like at home or work or a public wifi.
I shot the developer a note asking why SanDisk was needed and got the following response. Sharing for those that are curious.That makes sense, but seems odd to limit the functionality like that. But I'm not an App developer, so what do i know?
There is also the non-wifi version where you can plug one end into the lightening port and the other end is USB. Its cheaper.
I was looking at this one as well, so I just emailed the developer to see if this would work. Here's his response:This is the one I use: https://www.amazon.com/gp/product/B01CIEBXZG
But I'm not sure if it works with this app.
The SanDisk USB Wifi is an AP itself. It has a battery built-in to provide wifi connections (~2 hrs).
You can download SanDisk's app to view the files including TeslaCam videos but its only and single screen.
You switch your wifi network to it once you press the button on the side to turn it on. Yes, it has to be unplugged from the USB port before you can turn on the wifi AP. While plugged into the USB it charges the battery.
This setup allows you to immediately view the videos in the car. I believe there's a SanDisk app for both iOS and Android.
the stick creates its own wifi network. the app connects to it. you can use it on the moon with no other network.So does it need to be on a wifi network like at home to use this? Or can you just hotspot your phone or what am I missing? Can I access this In the middle of nowhere?
