Short range battery software locked?
Discussion in 'Model 3: Battery & Charging' started by cyber3, Oct 11, 2017.
  1. cyber3
    cyber3 New Member
    Nj
    Hey folks, I was just wondering if you guys thought the short range battery on the model 3 would be physically limited to 50 KWh or would it be limited using software like the Model S 60 was. Just wondering with the production delays whether Tesla would default the battery size on all 3s and have glass roof on all cars regardless to speed things up.
  2. run-the-joules
    run-the-joules Active Member
    SF Bay
    It's a physical difference unless they're including a fat guy to explain the weight difference between models.
    • Funny x 5
  3. PoitNarf
    PoitNarf Member
    NJ
    As stated, the curb weights for both the standard and long range have been released by Tesla. No software locked battery on the standard. And having a default battery size and glass roof is already the case with the initial production. All cars built now all have the long range battery and premium upgrade package, so it’s as streamlined as possible when it comes to options.
    • Helpful x 2
  4. Troy
    Troy Active Member
    Hi. The Electrek article here says the large pack has 4,416 cells and the small one has 2,976 cells. Therefore the answer is no, the small back is not a software limited version of the large pack. Also, the small pack is 55 kWh, not 50 and the large pack is 80 kWh, not 75.
    Model 3 80
    Actual capacity: 80.5 kWh (350V*230Ah= 80,500 Wh. Source for 350V and 230 Ah, see page 3 here)
    Usable capacity: 78.27 kWh (Source: see page 6 footer here)
    Cell count: 4,416 (source)
    Model 3 55
    Actual capacity: 54.25 kWh (This is an estimate calculated from cell counts: 80,500/4416*2976= 54,250 Wh)
    Usable capacity: 52.75 kWh (This is an estimate calculated from cell counts: 78,270/4416*2976= 52,747 Wh)
    Cell count: 2,976 (source)
    • Informative x 4
  5. brkaus
    brkaus Active Member
    No
  6. jtpassat
    jtpassat Member
    Providence, RI
  7. Pkmmte
    Pkmmte Le meow
    Los Angeles, California
  8. FlyingKiwi
    FlyingKiwi Member
    Auckland, NZ
    I think we have enough people posting "no" already, perhaps we could stop posting in this thread and let it sink to the bottom mmkay?
  9. dsvick
    dsvick Active Member
    NE Ohio
    No ;)
    • Funny x 2
  10. BluestarE3
    BluestarE3 Active Member
    Norcal
    That's what all those additional "No"s are for... to ensure there's enough weight to sink this thread. You don't want it inadvertently floating back to the surface later because we were too stingy with the ballast. :)
    • Funny x 2
  11. timk225
    timk225 Member
    Pittsburgh
    I suspected the small battery was much closer to 55 than to 50 all along! When I get my 3 and put Tesla name badges on the back like it should already have, I'll make it a 55 to better reflect the true capacity, including anti-bricking buffers.
  12. Uncle Paul
    Uncle Paul Member
    Canyon Lake,CA
    E 55 already belongs to Mercedes on their mid sized AMG performance package.
  13. ElecFan
    ElecFan Member
    Netherlands
    Hmm, the manual of the LR says the battery has a 75 kWh capacity.
  14. timk225
    timk225 Member
    Pittsburgh
    I looked at the manual online briefly, and it doesn't even mention the small battery. What's up with that?
  15. ElecFan
    ElecFan Member
    Netherlands
    It's not final yet, or it might be specifically for the LR.
  16. kWh
    kWh Member
    Texas
    Just for fun.... could the glass roof explain the fact that the LR and the Standard models?
  17. BluestarE3
    Norcal
    Long vs. short range isn't the same as PUP vs. non-PUP. PUP and long-range may be required for "first production", but they won't necessarily be linked in the future. For example, I'm planning on getting short-range with PUP. Others may opt for long-range without PUP. Also, I don't think there's a 265 pound difference between metal vs. glass for that tiny roof section.
  18. run-the-joules
    SF Bay
    Plot twist: Center console covers are 100lb/ea.
  19. Daniel T
    Daniel T New Member
    Portugal
    :p
  20. fazluke
    fazluke Member
    Yorba Linda, CA
