I deactivated my garage Wifi repeater after going to .16 from .12. The repeater and the architectural conditions only gave me a maximum of 6-8 MBit on .16 while the one bar of LTE have me 12-18 MBit. On .12 either gave me around 3 MBit max.
Right, it looked for a short while that they were using the same versions on the 3, but recently the 3 is back to having its own versions:
Except that it breaks things... no point rolling out a broken release any further, but the release system remains an opaque random process...Doesn't look like 16 has been pulled... and if they have the steering wheel heat already scheduled for 18, no reason to do so!
May be no point, but it appears that they are! As you say, especially weird when they even have the fix acknowledged and scheduled (for 18) and are telling people that (Erik has it on his YT video, as well as several others here).Except that it breaks things... no point rolling out a broken release any further, but the release system remains an opaque random process...
Maybe the new folks getting .16 are the ones without the winter package?
They need to get the word out to service center so they are not swapping steering wheels needlessly (and futilely)I just got a call from my SC.
I was told that the heated steering wheel fix was coming in 2018.18
As others have said.
Just adding another data point
Even if you didn't complain, no steering wheel heat for anyone!
Looks like 2018.16.1 is out according to TeslaFi. Anyone?
Admittedly I’ve got 27 hours of posts to read, but I’m assuming Tesla hasn’t figured out how to explain away this oversight. Imagine if instead of steering wheel heat they had disabled braking. Just plain old braking. Or current speed display. Or door unlock. How is this even an issue? I simply don’t undetsand how unit tests don’t make this a nonissue
Ah. My miss. Deleted my comment.
Try actually adjusting the EQ. At least one person said once they adjusted the EQ the sound returned to normal.
As I've said before, someone on our local facebook page had a similar issue and videod the sound and how there was basically no bass and adjusting the equalizer made no difference as well. Half his speakers weren't even putting out sound. On our suggestion he took it to the service centre where they acknowledged the problem and did 'something' to fix it. Whether they re-flashed the firmware or what I don't know but it's a software issue. You could try various levels of reboot to see if it helps.@MP3Mike I've adjusted the equalizer, and rebooted the vehicle many times to no avail. I build vehicles professionally, and I'm an amateur musician, so I do know my way around a sound system. The Premium sound has had degraded performance since 2016.12. I've been in email communication with Tesla and they are aware there is an issue with the sound quality / volume levels - it is not my ignorance of the equalizer controls, or my imagination that is the source of this problem....Plus it's an easy issue to hear; music I couldn't take at volume level 5 before now barely covers wind noise at 6-7...so you don't need a dB meter to detect something is different.
