Joe F
Disruption is hard.
They have an unfixable design flaw but they will never admit it. They will try to smooth it over as well as they can, forcing drivers into the less safe option of having only one hand on the wheel instead of two, because the torque sensor can't detect two hands on the wheel because each hand cancels out the torque of the other.
Not true if done correctly.
Statements like this by some here underscores the false idea that the torque sensor is somehow a failed method. It's not. It's a failure by some to understand how things work as currently designed.
Take a non Tesla car with no steering automation at all, and you have to steer manually, using both hands on the wheel. A curve in the road means you have to turn the wheel in the direction of the turn. Your arms move in opposite directions. If they did not, you would not be able to turn the wheel as your own strength would cancel each out. This is common sense and not something we humans don't have to think about.
Now take that example to a Tesla AP system. Your argument that your two hands cancel each others movement out, thereby nullifying the torque sensor from doing its job, makes absolutely no sense whatsoever. For that to be true, you would not be able to turn the wheel at all, and AutoSteer would disengage.
