Ok, I am looking for a sticky ... can't find.
Completely ignorant as to the how, why and where of solar.
Illinois.
Trying to determine how to recharge ANY EV with solar.
Obviously I would normally be charging overnight ... so it sounds like I am SOL?
But during the day ... how many "panels" would I need to keep the batteries charged up for either an S or a Leaf?
Can one store the energy in batteries? And can one then use a 240v inverter to power my Level 2 chargers?
And if I were to go all the way, and use AirCon during the day, would a size-proportioned roof full or cells be enough to stay off the grid?
Ahh... quite possibly. I'd need to go check about who got awarded what out of the big pot of DOE funding.Robert, I was referring to the power companies and the grid. Are they pulling a "Charge Point" type move y getting federal subsidies to build and then charge for smart (and dumb) grid work?
This appears to be a game changer that could revolutionize solar power production and make solar power affordable for nearly everyone. The oil companies are going to hate it. Now, if only we can figure out how to cheaply store the energy.
well Volker, you'll just have to build a larger house or design an addition to your currentt house . . . Perhaps a grandmother's cottage.CoolPV - Cooled Photovoltaic by ecoTec Energy
WIOSUN GmbH r Photovoltaik
Alibaba (lists a dozen panels from Chinese manufacturers)
Certainly an idea that I will go after for my next solar array, but right now I'm out of roof space...
Yep that and TEG's list are good examples. 800VDC is a bit higher than what you'd see in your typical residential system 300-500VDC is more typical. High voltage DC is also typically said to be more prone to arc-fault fires compared to AC since AC effectively stops arcing with each switch of phase. Certainly in the US working with only 120V potential energy from a hot wire to ground is less dangerous than working with hundreds of DC volts. One drawback of the lower voltage to the roof is that this often requires slightly thicker wires to carry the current. But this is often negated by the fact that you can use plain old Romex instead of THWN2 rated wire in conduit.Another BIG benefit of micro inverter would be increased electrical safety. All inverters shut down on power outage, but conventionally built arrays still have up to 800V in their DC lines. That is a real concern for firefighters here.
If I understand correctly, the micro inverters work with DC input voltage of a single panel which is around 40V = harmless.
I still have trouble seeing anything <115kV as "high voltage", but that's just an occupational hazard with me.:biggrin:300-500VDC is more typical. High voltage DC ...
