JRP3
Hyperactive Member
Yes, I'm guessing very low, and made worse by the mostly poor angles on a car body in the case of a wrap. Hopefully I'm wrong, but if history is any indicator I'm not.
Not holding my breath for this one, but it is solar: http://www.space.com/15189-solar-power-beaming-satellite.html
That's a little overstated, Brian -- NYC is only about 13GW peak. Still, there are going to be much more economical solutions for renewable power than orbital solar.
That's a little overstated, Brian -- NYC is only about 13GW peak. ... .
Astronomy? The light is bounced outwards to the solar cells, and microwaves are beamed down. Might interfere with some bands on radio telescopes, I suppose.
Its "thousands of megawatts" is only gigawatts, though, and cities eat gigawatts for snacks.
Should be easy enough to manage. The solar cells will face the sun, and can be angled to reflect away from the planet. The Moon's surface is simply a rough chaotic natural reflector, and bounces in all directions indiscriminately.
In any case, the collectors will be relatively tiny, nothing like the angular size of the Moon.
Yes, but a LOT closer. The ISS is already quite bright, and it's tiny in comparison to one of these things. On the night side of the planet, the collectors will be aimed at the sun, which is roughly in line with the Earth, so it will be impossible angle it away from the planet as you suggest.
Through March, we have seen a 50% increase in the number of Net Energy Metering applications received into our office/team. With only three months completed, that is a rather substantial increase in work and given that in 2011 we completed a record number of solar installations for the year (13,513) we may be on the way to an even larger number of solar installations in 2013.
In 2011, we had received approximately 2,600 applications for solar installations during January through March -- for 2012, we have received nearly 3,900 applications.
You can see the numbers here by adjusting the filters: California Solar StatisticsIn an email exchange with PG&E:
