But most people don’t need anywhere near a 10kw discharge capability.Most people think this way, but that's not the main issue.
It's not the storage capacity that makes it clever... it's the 10kW discharge capability.
If you had one Powerwall, you're restricted to 3.6kW or 5kW discharge.
So even if your Powerwall is full, brimming 13.5kWh of energy stored... if you then turn on an 8kW electric shower (or a 7kW car charger, or 7kW induction cooker, or 3.5kW Emersion heater)... the Powerwall can only deliver 5kW... so anything over 5kW has to come from Solar excess or Grid at peak rate.
Let's say your base house demand is 2kW during Winter with Heat Pump active. You've then only got 3kW capability left, to keep you away from Grid Power. For us, that isn't enough.
In Summer, you might stand a chance with Solar... but in Winter, two Powerwalls give you that extra capability to stay off-grid at Peak Rate costs.
That's why two Powerwalls are the sweet spot.
So it goes back to the original point of the extra £8k for another Powerwall just not having a payback.
2kwh baseload is something!
