There is a little "pinhole" in the paint on the inside of the lip. The 2 set screws have a point on them to purposely make contact with the bare metal on the inner surface of the lip.Barry,
Any damage (paint? sheet metal?, weather stripping?) with the Comet lip mount? Did you end up mounting one on your Tesla? If so, where did you mount it?
K6SLB
this. Or an EMP, solar flare, war, false flag, major earthquake, tsunami, hurricane, etc.. don't think for a minute you can rely on internet and/or cell phone in major emergency situations. Always have a backup, and a backup for your backupMy HF rig is in the basement waiting for the apocalypse.
I'm not an antenna designer, but there's an apparent contradiction in this: using a magnet to stick the antenna to a steel roof wouldn't seem to make an electrical connection through the paint any more than using suction cups to stick one to an aluminum roof...or does it?
Most ham VHF mobile antennas are 5/8 wavelength.However most magnetic mount antennas are 1/2 wavelength and thus do not require electrical conductivity with the ground plane to function properly.
Give up ham radio? I'm only half kidding. I've been licensed since I was 17, but gave up the hobby about 10 years ago. It's slowly dying.
On the MS with the pano roof there are mounts for a roof carrier. You could use those as a base. Perhaps a small metal bar across the roof to act as a ground plane.
A
The windshield is conductive enough to cage MHz from the car interior (but not GHz). Anyone tried it as the ground plane? de WB7RAY
Well, I hope you keep a backup HT in a strong Faraday cage, because an EMP will probably kill all of it! =)
William, could you explain this? Glass is an insulator, and normally transparent to RF. Is the Tesla windshield doped with something that makes it conductive? And even if so, I would expect the effect to be even more pronounced in the GHz than in the MHz. I would like to understand...
............With all the web connections possible to remotely control your own home radio - whatever band - I almost wonder if you need to petition Tesla to build an app for that... rather than mount an antenna...
de VA7AV
As the hardware is configured today, I don't see why not. It can stream music from the Internet (Slacker) and the voice recognition ("Play Rolling Stones") appears to do the processing remotely. I say *appears*, because that is my impression and I have no hard facts to back that up. But both being true, it would presumably be possible for two way audio.I don't even remember the last time I was on. Probably doing some storm watching for Skywarn, but it's been at least a decade, probably longer.
One could always try Echolink. It uses streaming 2-way audio and the internet to talk over the whole amateur radio spectrum. I played with it once many years ago just for grins and logged into a 2m repeater in southern Illinois and actually managed to hook up with a couple of hams up there who knew a friend of mine from that neck of the woods.
Would the Tesla browser even do 2-way audio?
Have any of you got an HF setup on a Tesla?
I've a Model X (yes, I know, wrong forum, but again: new thread seems like a waste); and at the moment I'm just planning on pseudo-duplicating Ditpixs's setup, to start; Diamond ‘trunk-lip’ mount, RG316 through the passenger compartment and firewall up to the frunk, where I'm planning on installing the body of a ICOM IC-7100 (which are on wild sale right now — usually $2,000 MSRP, and $1,100 on Amazon, HRO is selling them for $980, with an additional manufacturer's rebate bringing it down to $880!), both to get it out of my way / give it room to stay cool, and to get easy access to the unswitched 50A terminals; then finally bringing the remote control/head-unit back into the passenger compartment, where I plan on replacing the ‘cubby’ underneath the touchscreen. All tentative, mind you.
However, I'd really like a mobile HF setup (I live in an apartment, in the middle of downtown, in Chicago — there's not really a lot of opportunity to go stringing long antennas, or setting up anything exotic, at home; not to mention that I take frequent and long roadtrips all around the U.S. … so my vehicle is really going to be my only HAM base-station) — probably a screwdriver antenna, mounted to some sort of L-bracket mounted under the rear bumper to the frame of the car? I'm not sure yet. Anyway; I'm very noob, but: I hear horror stories of HF rigs playing havoc with old-school traditional cars … which makes me terrified about what it might do to a Tesla, with all the tech in her! And although I'm just planning ahead right now, if I'm never going to be able to run any sort of worthwhile HF setup on her, then it seems silly to buy an all-band transceiver; I could get a much-cheaper, much-higher-quality UHF/VHF transceiver. (Although, still, woahbuddy, that ICOM deal.)
So, tl;dr have any HAMs here got hamsticks or a screwdriver or something on a Tesla? Is it not worth the effort, slash is it going to screw with all the electronics?
Hate to add to the debbie downer; Like Andrew and you, I've been a licensed ARO for 20 years. Not used it in 10. Slowly may be an understatement.
