Solution to charge your Model 3 if you don't have any garage?
Discussion in 'Model 3' started by Oyinko, Apr 23, 2016.
  1. Oyinko
    Oyinko Member
    San Francisco
    I was walking in my neighborhood (Noe Valley, San Francisco) this morning and came across this plug coming out of the sidewalk. The plus was charging a Mercedes. I guess the owner used the underground pipe to connect the plug to his house. It's a pretty discret solution that doesn't leave a cable on the sidewalk as I have already seen many times.
    And the best news of all: I have also a similar plate in front of my house :)
  2. stopcrazypp
    stopcrazypp Well-Known Member
    That's clever but likely also a code violation. You aren't supposed to share water based utilities through the same trench as electrical, much less inside the pipe itself.
  3. Topher
    Topher Energy Curmudgeon
    Maine
    What makes you think the pipe is water related? It looks to me like the sidewalk was cut, a conduit added, and re-cemented. They probably should have painted it though.
    Thank you kindly.
  4. StraightDave
    StraightDave Member
    Dallas
    Not a bad idea. I'm going to run a plug from my neighbor's house.
    • Funny x 10
  5. BluestarE3
    BluestarE3 Active Member
    Norcal
    Does he have exclusive use of that parking space? Would suck if someone else parked there and the owner can't get to his own charging cable.
  6. Oyinko
    Oyinko Member
    San Francisco
    The spot was in front of his driveway so I guess he is the only one using it. He had also another plug next to his garage door which makes me think he has 2 electric cars.
    I'm not sure if the hole is for the water pipe but it's definitely something related to the city as most of the houses have one in the sidewalk.
  7. stopcrazypp
    #7 stopcrazypp, Apr 23, 2016
    That cover is a common occurrence in San Francisco. It is a sewer vent that in general helps to prevent odors from the sewer line getting into people's homes, but is sometimes used for clearing blockages in the sewer line from the sidewalk (I know because I've seem plumbers clearing clogs using a snake through that cover).
    So a cable through there means it must be either snaked through the pipe, or very near the sewer line.
    Missing Sewer Vent Covers | San Francisco Public Works
    (see page 12 for diagram)
    http://www.sfwater.org/modules/showdocument.aspx?documentid=580
    Given the cover shown doesn't have holes (the one next to it does), it might be a general cleanout (so not air venting).
    http://www.mountainview.gov/civicax/filebank/blobdload.aspx?blobid=6978
    The sidewalk was likely cut to install the sewer line, not to install the conduit. Look at how old and rusted out the cover is.
    I'm not a plumber or electrician, but from working on some projects with P&GE (the local electrical/gas utility company in San Francisco) they will not let you install electrical wires through the same trench as "wet" utilities (this includes water and sewer).
    If that cable is the cable from EVSE to car (meaning it is not energized when not charging) that might be more acceptable, but if the EVSE is on the outside (meaning cable is always energized), then it creates quite a bit of danger for the plumber who might have to use that cover when clearing a clog.
    • Informative x 3
  8. DrPhoton
    DrPhoton Member
    San Diego, CA
    Interesting. Many places it's illegal to park in front of a driveway, even if it's your own. Also, the cord is a potential trip hazard to pedestrians. I see lots of possible problems with this approach (sorry!). I would imagine that a better solution would be to have a trench in the sidewalk with a removable cover and an above-ground plug in the yard. This approach would permit a safe above-ground electrical connection with a safe pathway to the street parking spot (assuming there is some way to reserve that particular spot!).
  9. FirstSea
    FirstSea Member
    United States
    Hijacking this thread for a somewhat similar dilemma.
    To put it simple, there is a very high probability that I'll have to relocate from CA to TX, if that were to occur I will be renting an apartment, as buying a home right after seems like a terrible idea. What would be the best way to charge a 3, I might have access at work, but I'll rather plan incase I don't.
  10. Tes LA
    Tes LA
    Pasadena, CA
    I'm interested in this as well. I certainly plan to be moved into a house/townhouse by the time I get my III but that's not a guarantee. I would like to know if anyone has experience with this in an apartment complex.
  11. stopcrazypp
    I don't know how viable this is in TX, but in CA it is possible to rent a private garage and as long as it has at least has a 110v outlet, that can give you 30 miles of range overnight. Then the rest you can supplement with work or public charging, which you can locate with plugshare:
    PlugShare
  12. Jackl1956
    Jackl1956 Active Member
    Los Angeles
    It makes great sense to invest the money in a long term charging solution. Reliable charging will multiply the utility and satisfaction of your Model 3 purchase.
    Just my 2 ¢.
  13. CarlitoDoc
    CarlitoDoc Member
    Yakima, WA
    Dang....what a PITA! Understandable in big urban areas.
  14. Tes LA
    Tes LA
    Pasadena, CA
    I had no idea about PlugShare! Thanks a lot and I just signed up. Looks like I live smack dab in the middle of tons of charging options, but hopefully by that time I'l have a more permanent solution regardless.
  15. FirstSea
    FirstSea Member
    United States
    Thanks stopcrazypp, I didn't know such resource existed.
  16. cpa
    cpa Active Member
    Central Valley
    Yes, I find it ironic that these technological conveniences and information like PlugShare rely upon word-of-mouth.
  17. TaoJones
    TaoJones Beyond Driven
    The Americas
    One can only hope for greater integration of PlugShare and evtripplanner.com into Nav/Trip Planner. Especially now that a certain intern is onboard.
  18. Drivin
    Drivin Member
    just use a supercharger. that is what they are there for.
    • Disagree x 5
  19. ImEric
    ImEric Member
    Los Angeles, CA
    Even better news: your neighbor already ran a line for everybody to use!!! :D
  20. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    Uh, no...
    "Superchargers are used for long distance travel, conveniently located along the most popular routes in North America, Europe and Asia."
    Supercharging
    With regard to locals charging, Tesla frowns upon it, although Elon Musk did say "it's cool to do occasionally" but he also said he doesn't want it become a regular habit and those who do use local ones got letters to that effect. Tesla knows when each car uses a supercharger so to expect to be able charge locally on a regular basis with the Model 3 doesn't seem like something that Tesla will allow, or that will work, since it will clog them up for those travelling through, unless Tesla changes the entire purpose of the SC network, which seems highly unlikely to me.
    • Disagree x 1
