hridge2020
There are only a couple of tire choices when you've got the Performance with 20” rims.
I have 18's
Yes it did.. the final thing I did was the door seals recently... ultra quiet...
My next set... Is the tires, I've done this in the past of my other cars and found that the thread patterns are also to blame for road noise..
I will be checking out the tires more in detail when mine get close to wearing out. see image.
This is the rubber seal that I used: https://www.amazon.com/gp/product/B07S7P5P51/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Here is the picture of the trunk lid after installation. It significantly reduces vibration of the trunk lid and reduces noise coming in.
Also - I decided to remove the "spare tire" cover. I went into the trunk and found it was a source of tremendous sub-bass. Simply by tapping on it you could hear the resonance like a bass drum or subwoofer. I removed it and put a down comforter in place of the spare tire area, and low and behold, a huge reduction in sub-bass frequencies on the highway!
View attachment 464723 View attachment 464725
Interesting. I bought a little organizer box for that area and stuck a bunch of stuff in there, so I can't just fill it with a blanket. But maybe I'll try adding some sound proofing foam to the underside and see if that helps at all.
I use that area in my car. Do you think just sticking down some high density foam (like a yoga matt) at the bottom/sides would do anything?Also - I decided to remove the "spare tire" cover. I went into the trunk and found it was a source of tremendous sub-bass. Simply by tapping on it you could hear the resonance like a bass drum or subwoofer. I removed it and put a down comforter in place of the spare tire area, and low and behold, a huge reduction in sub-bass frequencies on the highway!
Those rubber seal kits aren't worth the investment. I turn up the premium audio system and enjoy my tunes!
Most of the road noise is a result of sound transmitted through the suspension to the chassis. It's not the only car where I've experienced this. Had a rental Nissan Maxima a while back that exhibited the same dramatic difference in noise level based on the road surface. I was surprised by that, as it was SO different than the Audis we'd owned for years, where the difference was much less pronounced.
This is why adding all the dynamat/gaskets doesn't eliminate the issue - those items don't address the source of most of the noise.
Also, the glass roof, while "cool", definitely doesn't attenuate sound the way a traditional headliner-equipped roof does.
It's honestly the only thing that actually bothers me about the car.
I agree the M3 could be quieter. That said it’s really not much different than some of its ICE competition re; Q50, G70, or even the pre 2019 BMW 3 w/sport suspension.
If you look at my picture carefully, you can see that I put the seal on my trunk lid's edges only and so it does not interfere with any of the existing seals.So I went to install this and careful analysis showed me that it would interfere with the current seal in many places. I identified the area with the largest lack of a seal, and which way to install it to create the best seal.
What I ended up with was the area along the sides and also on the lift gate itself only for the area sealing the taillights. Unlike the doors, there isn't much to improve on the trunk.
It would be nice if someone developed a kit to dampen some of the suspension noise.
We'd need something to dampen noise where the suspension is connected to the chassis... if there is such a thing.
I’m in the process of doing that in hopes of quieting the road noise. Having done a few cars now over the years I personally think that using Thinsulate acoustic insulation works better and is WAY lighter than the mass loaded vinyl. I’m also using the same Noico “dynamat” material that the OP used.
