So this is going to sound weird, but then again that's why I'm posting here, so...
I have a big red 1.5 ton scissor jack that I used to keep in my MS for emergency cases.
I have raised the MS a few times using that jack and it works fine. I have also tried using that jack on an Odyssey and that worked fine too.
Recently sold the MS and got the M3. Tried the same jack again on this car, and for some reason it is very hard to lift.
I keep turning the screw and have to put in massive amount of effort just to make it turn and lift the car. In fact I had to stop because I was having to turn it so hard that I was afraid something might break.
I thought maybe jack is bad, so I tried it on the Odyssey again, which is a much heavier car, and it works fine, very easy to turn the screw and lift. Tried it again on M3, same issue, very hard to lift.
This is just bizarre to me, since M3 is a lighter car by almost 1000 lbs so I see no reason I should have any issues. I ran out of ideas, so maybe someone here might have experience lifting the M3 using scissor jack? BTW I am already using the proper jack pad so I don't think that is the issue...
