Occam would agree.My (likely) theory is the lack of drive shafts and wiring to the front wheels means the document is not accurate.
no reason to apologize if one thinks a car looks idiotic. Our Nissan Leaf is the Paragon of looking idiotic, imo. But at least it ostensibly served a purpose. Low drag CD. However this new Prius Plug-In, with less than it's sister hybrid's 5 seats, has a crappier drag CD. The company chose to deliberately ignore drag over this kind ofJapanese Power Ranger animation thingy going on. Hey, perhaps younger buyers don't mind.....snip.......
As for the "weird" aspect... I actually like... no, love... anything that's traditionally considered "weird" but reduces drag. I love sleek, low-drag forms. Shape it like an airplane and you have my heart. The Prius Prime, however, has its weirdness (sorry SageBrush... ) in its styling, factors with no bearing on drag. But, of course, people can disagree about looks!
There's no drag advantage to that "moustache" tail or those "gills" / "mandibles" on the front. No weight advantage. They just... wanted it to look like that for some reason. And some of the details are just strange .....snip.......
considering how much lawsuit saber-rattling there was when it was discovered everyone's top performances we're being throttled back after so many uses .... it would make sense that from here on out - such performance limiting will be well-documented & require signatures before anything with performance happens again.I would vote that there is more power available than 192kW/ / 258 HP
Could it be it default runs in an efficiency mode with that power (and doesn't do 0-60 in 5.1) unless you get it into some kind of Sport mode?
I don't think there is any switch we saw for sport/insane type alternate modes, but maybe there is some not yet published way to bump up the HP when you want quicker 0-60?
Has anyone heard anything about special launch modes?
So when I plugged in all the values necessary for the Model S (different tires, mass, frontal area, cd, motor curve, final drive, etc), I got what I would consider pretty damn close:
Not shabby IMO. Great, so let's try the M3! This is where it got interesting......
- 0-60 = 4.45 sec
- 1/4 mile = 13.1 sec @ 107 MPH
When I used all the M3 data (tire size, mass, etc.) it came up short from 0-60. It was predicting 0-60 in 5.84 seconds. We know the LR (which is what all the parameters are based off) should be at 5.1 seconds, so what are my levers? Even driving the transmission efficiency to 100% (impossible), only gets me to 5.5 seconds. Lower resistance tires can't get me there. I can't change mass, tire size, final drive ratio, frontal area, or Cd because we actually know these things. I'm open for suggestions of what to try, but my only option was to go to the torque/power curve. Again, the curve is completely flat for basically ALL of the 0-60, so you can't really say it's how I modeled it. I found that if I applied a 1.14x multiplier to the output curve I came in at 5.1 seconds. That would mean that instead of 192 kW motor, it's more like 219 kW (346 HP)! By the way with that 1.14x multiplier I now get:
Summary:
- 0-60 = 5.1 sec
- 1/4 mile = 13.9 sec @ 101 MPH
- I know my first order estimates do NOT consider traction, I'm ok with that for now.
- Something is off with the data, they still aren't coming clean with this car. Either more powerful motor than advertised, lower mass, or ???
- This message is to further the thread...."Tesla has created a monster!" and I don't think they are ready to fess up yet!
- If your interested in the calcs, here's the google sheets:
- Tesla quarter mile calcs.xlsx
I thought they only did that for the Performance models?If you also take in account that all Tesla measures uses an one-foot rollout during the 0-60 (which improves values a bit) this 5.26 seems about right.
Thanks for the update...But after this refresh Tesla started to use only one type of measure, the one followed by Motor Trend's which remove the first foot rollout.
On the Norwegian page no models got that comment, but it is written at the bottom of the page under the title "Performance" (yes, title in English not Norwegian, as it is on the model name), which I would interpret as "Performance models only". The rest of the text is translated. So this is just like it has been for awhile."Performance acceleration ratings are based on maximum battery power mode and follow Motor Trend's test procedure of subtracting the first foot rollout time to represent drag strip performance.
Good catch. Yes, it appears that I somehow used an incorrect mass. I don't know where I got it from. Again, thank you for checking my math!I think the problem is the wrong value for mass you're using: 1928 Kg instead of 1740 Kg. Check the EPA document for Model 3 curb weight : 3837 lbs.
Reseting your multiplier and using the correct mass results in a 5.26 sec to 60MPH. If you also take in account that all Tesla measures uses an one-foot rollout during the 0-60 (which improves values a bit) this 5.26 seems about right.
It's from wikipedia's high end weight listing (someone should fix it).I don't know where I got it from.
Good catch... Makes me feel less like a idiot...It's from wikipedia's high end weight listing (someone should fix it).
insaneoctane,
A challenge for you if I may :
Taking in account (for instance) that the Model 3 LR - 75kWh battery pack can output ~403 kW of power (and the inverter also supports it), what torque/power do you think the motor should have to give a less than 4 sec 0-60 mph ?
By definition of every Tesla torque/power curve I have seen, this is easily done by 403kw. By the way, at 403kW (540 hp) you are at 775 Nm (571 ft lbs). You only need about 273 kW and 525 Nm (367 Hp and 387 ft lbs) to get under 4 seconds.
There's no doubt they will software limit itShould also add that I don't see Tesla offering a 3.0 sec Performance Model 3.
It would be too similar to the current P100D for less than half the cost.
I think a value of ~3.8 sec would be good enough without entering too much into Model S territory (2.5 - 4.1 sec).
Hmm. So you are saying that they will overspec the DU, inverter, battery, etc. for their highest performance 3, and then software limit it to perform below capability even with absolutely no intent to use the extra capacity? That would only possibly make financial sense if they were using the same components in another high volume vehicle (so not new roadster) that would use the full capacity. I don't buy your logic.There's no doubt they will software limit it
