stopcrazypp
Nope. The car is motor power / motor torque limited between ~13-25 mph.Maybe it's semantics but isn't the car never torque limited (ie max motor torque which is not the same as max torque delivered by the motors limited by current), it's traction determines the max acceleration which is sustained until the battery limits on current draw kick in which determines when the acceleration drops?
Remember, the motor power includes the limits of motor controller and inverter (more accurately it is the drive unit limit). S85 has a 900A inverter, P85 (P85D rear) has a 1200A inverter and post-P90D rear ~1300A, 70D/85D front and rear (P90D front) ~650A. All of these limit the amount of torque the given drive unit can output independent of traction limits.
The fact that the increase in motor power from 728 hp of the P85D to 762 hp for the P90D launch raises previously measured acceleration from 1.05 G to 1.1 G shows that the tire traction limit was not reached yet under the P85D.
However, even ignoring that point about inverter limits, motors don't have infinite current or voltage carrying capabilities, nor can it physically handle infinite torque/power. I've seen claims that motors can output its rated power at all rpms, but this is false given the torque limits (and back EMF). If it was true that motors can handle infinite torque/power, there would be no need to keep a physically bigger motor for the rear for the P85D/P90D vs the 70D/85D. All Tesla would need is the smaller motor unit and then software limit it, but that obviously is not the case.
