I think we define "openly hostile" differently.Not every company in the world is openly hostile to their users. I will blame the company.
It was broadcast traffic being sent out. So that goes to all ports.I find it odd that traffic was able to be sniffed here in the first place... generally ethernet switches prevent this.
Many ways to do that. Either they open up Ethernet via a command on the CAN bus or they have a magic packet that they send to the switch that unlocks things or...If it truly is locked down, then how do you suggest that service techs are still able to connect their laptops to the same diagnostic port? What means are they using for authentication?
sounds like they went to unicast only traffic and either turned off ping responses or changed the ip's of the units.Hello all, same thing here. The ethernet connection goes up, but no traffic at all. And ping on devices doesn't work. Game over !!!
what constitutes a connection to Tesla's systems for access? I vote you try a replay attack to trick the system into thinking you have access to their systems
You give up too easily.
if you want to continue, here's an idea.
Trace the cable and find the switch.
Make adapters for each ethernet cable going into the switch to standard rj45. Good adapters.
connect them to a standard hub instead and you'll be able to see all traffic and not just broadcast.
when done logging just connect them back to their original switch.
I thought you said the ethernet link went up as expected?It seems the connection was killed somehow "physically".
I was thinking of changed IP addresses etc, so I tried rebooting the main display by holding both wheel buttons on the steering wheel.
ARP query was expected to be broadcasting from IP address of the main display when it started talking to other components like dashboard. However nothing was captured.
The link still comes up, but no traffic at all.I thought you said the ethernet link went up as expected?
ARP querys can be turned off. They're not really needed if you only have known devices on a closed network.
Maybe. If the switch supports vlan's.The link still comes up, but no traffic at all.
Yes, you can set static ARP entries, but all cars will have different MAC addresses for their devices, so I doubt that's it.
Maybe they simply put that port into a VLAN of it's own?
Since the network transporyed data between dashboard and center displays, probably not.Or it could be that the network is already isolated by a router and the routing can be enabled or disabled by CAN command or remotely?
Then the ethernet link wouldn't go up either.Switch port turned on/off by a setting in the DIAG menu of the car?
