Having seen many hundreds of charging graphs for Teslas, I've seen charging results across the board. I've seen vehicles get consistently lower results than others, I've seen vehicles get randomly lower results than others, with no explanation for the random changes - sometimes permanently lower, sometimes jumping back up afterwards, with no explanation. I've seen chargers give consistently lower results than others at the same station with the same nameplate, stations get consistently lower results than others with the same nameplate, and I've also seen the same sort of lower results occur randomly with no explanation for the random changes... just suddenly, lower. Sometimes consistently lower after that, sometimes coming back up, with no rhyme or reason.
I've seen enough of this sort of stuff to know that you can't rate an update based on a single person's charging graph.
That said, it's certainly plausible that charge rates were limited. If lithium can't reliably intercalate faster than a given rate into the anodes, you don't want to try to force it. Intercalation is a physical limit; if you try to push past it, you'll be plating out lithium metal instead, which you don't want. The BMS always limits the charge rate for this purpose. The only thing Tesla could plausibly do to boost intercalation rates would be to increase the temperature, although that will shorten battery life via increased anode-electrolyte reactions.
