You have a lot of ideas here to experiment with.
The grade is the same 20' from the garage as it is at the garage and autopark seems to start up fine so that seems to rule out grade. Except the Tesla support guy still thinks grade.
The lip is certainly an issue but can be shimmed or removed and might not be a problem if the driveway is more level.
I'll turn off tight tolerance and see if it centers and works better. I have tried long and short runups and they don't seem to affect it enough to succeed.
I have the car in the garage now(manually) so I'll see if I can summon it out. Unfortunately it's a big drop into the garage so might now get up the hump to get out either.
I have not figured out how to initiate autopark from the screen, will look into that.
