Than you very much for the data point.
i should arrive in Tarrytown later this afternoon with roughly the same amount of rated range as you have. what stall did you plug into? i'm partial to 1A if available.
i'd say 96 kW isn't bad btw.
Either way, at 12:30am your only two choices are drag your ass out of bed in the middle of the night and lose at least an hour of sleep (when you are likely only going to get maybe 6 hours total) or just leave the car plugged in all night.
Time to upgrade to the dual charger.
Sorry, for new cars then: time to upgrade to the high amperage charger option.That isn't a thing any more. Just for old cars. Now there is a high amperage charger option.
Plan to get there earlier or leave later. Otherwise plan to get less sleep that night. Poor planning Is no justification for inappropriately blocking that space.
I have never used a Supercharger as I haven't taken any long enough road trips in my car yet, but in his example he is arriving at 12:30am and leaving at 8:00am. I have a P100D, and if I arrive at 12:30am with say a 5% SOC and want to go ahead and charge to 100% since it is an overnight stop it is going to take somewhere around 2.5 to 3 hours to charge at the supercharger, right? A destination charger likely wouldn't be able to charge the car even in the full 7.5 hours, so what choice do you have in that situation if you need a 100% charge? (don't say a 100% charge isn't necessary, because sometimes it is)
Just plug in to the supercharger at 6 am and leave at 8 am. Or, pick a hotel with a destination charger.
GSP
You didn't read the posts above, as those options were all debunked. Getting up in time to plug in at 6am means you only get about 4 hours of sleep endangering yourself, your family and everyone else on the road and a destination charger may not be able to fully charge your car in the short amount of time available.
Getting way off track here. The OP was plugged into a supercharger overnight and said he WANTED to charge to 100% since he was charging overnight, not that he NEEDED to. I pointed out that if he didn't want to move his car from the supercharger, perhaps he should have chosen a hotel with a destination charger. You're right, if he had a 48A charger he wouldn't get to 100% in 7 1/2 hours, but he would add well over 200 miles of range. That's more than enough to get him to the next supercharger. Let's stop making excuses for his bad behavior.What % of Teslas have the twin charger that can charge at 80 amps or the high amp charger that can charge at 72 amps? Based on the order tracking spreadsheet it is one of the least selected options. The example the poster had said he was arriving at 12:30 am with a 8:00 am departure. It is not possible to fully charge a 100kW battery from 0% in 7.5 hours at 48 amps.
Wait, it is possible to plug in some else's locked car? I would expect that charge door to stay locked.
I can think of a bunch of things I would like to do (but wouldn't do) to a Tesla parked at a supercharger not plugged in. Plugging it in isn't one if them, temp sticker or no temp sticker.Here's another question then. A few weeks back I was driving from Utah to Truckee CA. I stopped for the night in Reno as I was tired and didn't want to show up at my friends place where I was staying in Truckee at 2am. The supercharger at that hotel in Reno was empty except for 1 other Tesla, parked, but not plugged in. I plugged in went inside and booked a room, and once settled in had charged enough to easily make it to Truckee (not that far). I then moved my car to the mostly empty lot for overnight. The other car was still there, not charging, 30 minutes later.
Should I have plugged in the other car? Idle fees might have been accrued on it as a lesson. (I didn't)
/edit Should add this unplugged car had a temp sticker in the window, it was clear someone had just bought it.
It is possible to plug in a locked car, I do it on my wife's S all the time.It's not possible to unplug a locked car. I'm not sure if it is possible to plug one in, or not.
Why? Is someone going to siphon off some electrons?If the charge port door can be opened while the car is locked, that's a flaw.
