Does he mean that the loss of a single tile will result in a total reentry failure and the ship disintegrating?Right now, we are not resilient to loss of a single tile
Probably in some cases. Just a 1% risk is way too much. 1% likelihood of a tile falling off multiplied by 1% likelihood it ends in the death of 100 martians is maybe borderline for space travel?? Also, if it affects reusability and requires repair then that won't be good enough for Elon.Elon tweeted:
I think "most places" would imply "critical areas". Bursting a tank would mean the loss of structural integrity of the vehicle. I doubt there are many areas on the vehicle that could tolerate a tile-diameter plasma torch intruding into the interior.Quote was "single tile in most places" e.g. loss in critical points.
Temperature is determined by relative speed. Decelerating more slowly may counterintuitively mean a higher temperature for a longer period, though counterbalanced by a lower pressure. Effective heat flux is maybe a better metric.Entry generates lot of heat energy. Distributing this energy for longer time interval lowers temperature. So deceleration must be as slow as possible. For that aerodynamic lift is needed to maintain max possible altitude. At those speeds lift can be generated only by keeping nose up, perhaps at 45⁰. 90⁰ nose up only after heating is not a problem and ship needs to avoid overshooting landing area.
Starship would need to have a nearly full tank (or at least 1/2 tank) to accomplish this, far in excess of its nominal payload capacity. This would require several extra Tanker flights and an orbital refueling stop per mission, but note that Tankers must also be able to reenter safely, without such a pre-reentry slowdown. Also it wouldn't be feasible for Mars entry, unless you're sending a fleet of expendable Depots along with every ship. Probably it would make much more sense to overbuild Crew Starship's heatshield at the expense of payload, and plan on losing a Tanker or non-Crew Starship (without redundant heat-shielding) every now and then, if the tile-only reliability can't be brought up to 100%.Why not have extra propellant and slow the ship down to speeds where heating becomes a more manageable problem?
How much extra propellant would be needed to slow down from orbital speeds of 25k kmph to say 10k kmph before hitting the atmosphere ?
Ooo! Ooo! Delta-v question!Starship would need to have a nearly full tank (or at least 1/2 tank) to accomplish this
Check your calculations? With Raptor v3’s anticipated 382s vacuum ISP, and 200T final mass (including landing fuel + reserve), I get ~408T of propellant needed to decelerate by 4166m/s. So a bit less than half a tank, but still a lot.Ooo! Ooo! Delta-v question!
Assume a 100 ton ship and 100 tons of cargo. It would need ~100 tons of propellant to reduce its velocity by 4166 m/s (15,000 km/h).
Attaching the tiles directly to each other (via wires at their attachment points, say, not gluing edges together) might help a single loose tile stay in place. (If it coming off anyway would be catastrophic, there’s not much downside to this.) Fabricating the tiles as a “metamaterial” that gradually and continuously changes composition from the outside (PicaX) to the inside (e.g. steel, or at least something more securely fastenable to steel) might also help. Biological structures do this all the time.I wonder if they'll try gluing on all the tiles. Or ceramic velcro or something. three steel pins per tile must be a good chunk of the mass of the system.
Weird. Not sure where I went wrong there. You're correct. If 100 tons of landing mass, it'll need 200 tons of propellant. If 200 tons of landing mass, it'll need 400 tons of propellant.Check your calculations?
I like it. I'm reminded of a wall of ivy. It either goes as a single sheet or not at all. And, in ivy fashion, do the velcro thing to keep it attached. If a tile detaches, the velcro could allow it to spontaneously reattach, even if only partially. Call Elon.Attaching the tiles directly to each other (via wires at their attachment points, say, not gluing edges together) might help a single loose tile stay in place. (If it coming off anyway would be catastrophic, there’s not much downside to this.)
Why would you want an ablative?Fabricating the tiles as a “metamaterial” that gradually and continuously changes composition from the outside (PicaX) to the inside (e.g. steel, or at least something more securely fastenable to steel) might also help. Biological structures do this all the time.
Brain fart, I meant HRSI ceramic. My point was that if connecting the current tile material directly to steel seems unreliable (as evidenced by tiles continuing to break/fall off), then tapering the material from HRSI on the outside to something tougher on the inside (perhaps via 3D-printing) might be a workable approach.Why would you want an ablative?
This is untrue, at least as a sequitur.Entry generates lot of heat energy. Distributing this energy for longer time interval lowers temperature
This was such a "cool" novel idea- a pity it didn't come to passwonder if SpaceX will go back to transpirational cooling
Part of the reason (I think) is that methane is really not the best liquid to use for transpiration. It pyrolizes in high temperatures, causing coking (similar to burning "fuel-rich") which could clog up the transpiration pores. LOX is not much better; pure oxygen is highly reactive. It's possible they could do the transpiration with a separate small tank of e.g. liquid nitrogen I suppose, although its heat of vaporization is less than half of methane. And maybe they'll do something like this for the most vulnerable, highest-heat areas, though probably not for the entire heat shield.This was such a "cool" novel idea- a pity it didn't come to pass
It begs the question of what the loss rate would be for ships without the additional protection. I also wonder about the volume of debris being dumped on points west of the Cape. Thirty eight percent of Space Shuttle Columbia was recovered, and that vehicle wasn't made of stainless steel.Not great, but not crazy, especially if it's eventually only used on crew Starship, or for landing high-value payloads. (Hubble retrieval anyone?)
