Blue Origin demands to cap the launch and landing of Starship from Cape Canaveral.Their main concern is "impact on local environment".
Right.Their main concern is "impact on local environment".
Remember a few pages back when conversation was about the Environmental Impact Statement for LC39A? See https://www.faa.gov/media/80626. Basically at this point the FAA is seeking public input for what things they should consider covering in the impact statement. Everybody can reply. So can you...oops, 6/24 was the last day, so it looks like Blue Original files at the last minute. It's moot now, but page 2 of that PDF describes "How to get involved".Blue Origin demands to cap the launch and landing of Starship from Cape Canaveral.Their main concern is "impact on local environment".
Interesting that SpaceX has apparently given up on the water deluge system. Perhaps out of concern over limited water supplies and how much water will be needed for multiple launches per week/per day.The second launch tower will have a flame trench of some sort. I would guess that it's of the same design as the flame trench at Massey's for static fires. But much more robust, of course.
I assume it will be able to accommodate Starship V3.The second launch tower will be taller than the first. As I recall, Elon said "a couple sections",
They are not demanding anything. They list a bunch of mitigation factors that they say should be considered.Blue Origin demands to cap the launch and landing of Starship from Cape Canaveral.Their main concern is "impact on local environment".
https://downloads.regulations.gov/FAA-2024-1395-0040/attachment_1.pdf
On the one hand, it's Blue Origin, on the other hand they do have a point, if Starship operations impact other space companies.Asks vs demands? Still not good for SpaceX.
Elon is not a fan.
Interesting to see the new concrete blast wall from the point of view of standing next to the OLM. That wall is massive! And oddly shaped, to me. A long rectangular section at the base and then it angles backwards.Part two.
You took the words out of my mouth, especially about the repetitious exclamations and the fawning. I'll pile on with Tim's bad habit of generally trying to get technical with Elon to the point of offering suggestions. Elon made the mistake of entertaining one of Tim's suggestions in the first interview, making Tim feels like a technical advisor to Elon.I am happy that Tim Dodd gets these Elon interview opportunities but quite tired of him constantly gushing “That’s crazy!” And “That’s insane!”. Yes. We get it. Now just get over it and please spend more of the limited time you have asking interesting questions instead of acting gobsmacked all the time. Maybe draft questions in advance and refer to your notes and ask them? There are so many things he could have asked about and didn’t.
I think it's built like a dam/ retaining wall (possibly without much below ground footing), base is ballast, then the wall tapers as total load (level arm remaining) decreases. Plus, the angle helps redirect the breeze.That wall is massive! And oddly shaped, to me. A long rectangular section at the base and then it angles backwards.
"the breeze"!!??the breeze.
It was late, I couldn't think of a properly descriptive term for exhaust + steam + water + dust +???, nor did I know the flow vector at that distance, so I chose humor."the breeze"!!??![]()
On the NSF zoom repost, you can just see the lift pins deflect a little under load.At 1:03 PM CDT on June 27, SpaceX performed the test that @mongo was speculating about, which is to secure the tank on the launch mount, then lift with the chopsticks to apply pressure to the rails. The only visible aspect of the test was the chopsticks moving up, and the landing rail being compressed as it contacted the lifting pins. There's no way to know how much pressure they put on the lift pins. It took several minutes for the visible motion parts of the test.
They repeated the test at 2:02 PM CDT, and this test was much faster, with visible motion completing in about 30 seconds.
Here's the live stream for anyone who wants to check it out. I'm sure it'll be in the next NSF weekly video.
