From Elon's twitter feed, SN3 is now on the launch pad for pressure testing, etc.
If it’s made of steel, not much.
Well that was interesting; the tank initially sort of crumpled in the mid-section and then slumped over when a jet of gas spurted out the right side (as defined by the camera view).
it didn’t appear to explode along a seam. But of course that camera view only showed one side of the vehicle.
In your first photo, looking up the side of the vehicle, on the right side, what are the multiple small cylinders for?
Great view of the structure that they use to simulate thrust to the thrust puck while testing without engines.From Elon's twitter feed, SN3 is now on the launch pad for pressure testing, etc. Maybe a hop if all goes well?
Elon Musk said:Yes, v close! Nice work. Those are V0.9 legs, so major upgrades coming. Need wider span, longer stroke & ability to auto-level for uneven ground or leaning into high winds.
I wish SpaceX would go with a more conventional rocket to send mass into LEO. They have a good engine (Raptor) and reusable first stage. Spend their time and expertise on innovative in-space components instead.
Disagree. Achieving 100% reusability is the essential first step required to lower the cost of access to space enough to enable the exploration and settling of the solar system. We will never see a permanent human presence on Mars without 100% reusability, much less a self-sustaining colony on Mars or even the Moon.I wish SpaceX would go with a more conventional rocket to send mass into LEO. They have a good engine (Raptor) and reusable first stage. Spend their time and expertise on innovative in-space components instead.
I meant a large conventional rocket. A single stick of at least FH capability. The problem is that such a rocket doesn't have enough customers to be viable, so SpaceX is trying to make a fully reusable large system, SS/SH, that's cheap enough to be economically viable even when it doesn't carry a full load all the time (full reuse means only fuel and refurb costs).Falcon and Heavy are the more conventional rockets, and are still successfully flying.
I absolutely love that SpaceX is bucking convention with Starship, and if they can succeed it will completely revamp the space industry. That's pretty amazing, IMHO.
A large conventional rocket would be operational years sooner (assuming SS ever becomes operational). I don't have a problem with SS as a research project.Its a bit of a muddy ask you're making--what do you see as the end goal/product and, as @mongo points out, how would your vision be materially different from what SpaceX is currently doing?
Yes, orbiter reuse is my main issue. If manufacturing SS is so inexpensive to manufacture then that would also make expendable upper stages less expensive.SpaceX has clearly proven that reusability reduces price per kg, which is the primary driver in pretty much any launch that's not state-funded, so it stands to reason that your vision would include reusability. Is your concern with the 'distraction' of making the orbital stage re-usable?
Going against convention is why SpaceX lapped the field. If Starship and Super Heavy work out, they will be 10 laps ahead of everyone else.I wish SpaceX would go with a more conventional rocket to send mass into LEO. They have a good engine (Raptor) and reusable first stage. Spend their time and expertise on innovative in-space components instead.
Have any reentry vehicles had a stainless steel exterior? I guess SpaceX is looking into some sort of standard heat shielding in the hottest areas ... but their plans change so often it's difficult to keep up.Both pretty fair points.
IMHO the timeline probably wouldn't end up too different. Unlike landing F9 cores there's quite a bit of precedent on atmospheric re-entry, so that technical element of Starship--which is the major difference from a conventional second stage+PLF--its much less an iterative science project and much more evolution of existing technology.
