Suspension Problem on Model S
Discussion in 'Model S' started by gpcordaro, Apr 28, 2016.
Tags:
Thread Status:
Not open for further replies.
  1. iKhalid
    iKhalid Member
    Ottawa, ON
    I have the exact same issue. Just went to the Mississauga SC at 6:15PM and had a tech look at it to determine if it's safe for my trip tomorrow to Ottawa; it turned out it's not. They asked me to come in the morning to hook me up with a rental since Enterprise was already closed and obviously they don't have a loaner for me in a such short notice. They won't be able to work on it until maybe Friday or Saturday. I hate it when I can't use my car when I need it. :(
  2. MassModel3
    MassModel3 Member
    MA South Shore
    Good thing you took it in! Glad they found the problem, but big suck on not being able to take it on your trip.
  3. Peter_M
    Peter_M Member
    Ottawa, Canada
    Sorry to hear that - hope you get your car back soon. Let us know what they did to fix it.
  4. Edmond
    Edmond Permanon
    Seattle
    A 2014?! What exactly was wrong?
  5. gpcordaro
    gpcordaro Member
    Connellsville Pennsylvanina
    WOW I am glad you found out before it was to late and had an accident. The only people checking their cars are the ones reading this thread or the mechanic type. What about the woman of non mechanic type men? Are they having the same problems? Is this causing accidents?
  6. JRP3
    JRP3 Hyperactive Member
    Central New York
    No evidence of such, so probably not.
    • Disagree x 1
  7. Dennis87
    Dennis87 Member
    Norway
    #227 Dennis87, May 25, 2016
  8. sorka
    sorka Well-Known Member
    Merced, CA
    The reality is IF this is a design flaw, we're going to start seeing crashes because of it as things start to break on cornering or hard braking MSs and it will turn into a safety recall. I just turned 222K miles on my Prius yesterday with $zero out of pocket repair costs. My recently sold Lexus turned 334K miles right before I sold it with no major issues for its entire 17 year life.
    If it's not a design flaw and is an isolated incident, then you're out $1500 additional dollars. If you'd signed the goodwill agreement and it later turns into a recall, you'd still have been able to recoup the extra $1500.
  9. sorka
    Merced, CA
    The OP wouldn't have known about the pre-mature wear had the ball joint not popped out. It popping out could be the fluke. The pre-mature wear could be the norm. Has anyone else had their ball joints inspected that we know about?
  10. sorka
    Merced, CA
    Wait, does the ball joint assembly doesn't have a grease fitting? How do you lubricate the ball joints without that???
  11. sorka
    Merced, CA
    How many miles did you have? i.e. how many miles left before they need to be replaced again but out of warranty?
  12. glhs272
    glhs272 Unnamed plug faced villian
    Burlington, WI
    Most vehicles today are not greaseable. Back in the day when I used to drive SAABs, the old 900 from the 80's had greaseable ball joints, then they dropped it.
  13. Avenger
    Avenger Banned
    Northeast USA
    Exactly. Cars built in the 1980s and before have grease gun fittings ( I own a grease gun that I used on my 1968 buick in my college days). In the olden days when a ball joint would fail, the ball joint could be pressed out of the control arm, then a new ball joint would be pressed back into the control arm. Today a mechanic orders up a new control arm with the ball joints intact.
  14. sheltz32tt
    sheltz32tt Member
    saratoga
    The Model S I am buying just had the driver side front Knuckle/Balljoint replaced. 2013 81K miles. Was making some pretty bad noises at low speeds and at park when turning the steering wheel to lock.
  15. badbot
    badbot Member
    apple valley, ca
    I would ask them to put in writing that ball joint separation is "normal" if they ask why say for the evening news.
    It looks like it was never lubed. How many miles are on it?
  16. iKhalid
    iKhalid Member
    Ottawa, ON
    Will do. Thanks!
    I will post about it once I get the car back. From my understanding, these things happen even to brand new cars.
  17. Peter_M
    Peter_M Member
    Ottawa, Canada
    51,904 km.
  18. sorka
    Merced, CA
    So if it occurs again at the same rate, it's have 64K miles on it the next time and be out of warranty. That's nuts.
  19. Peter_M
    Peter_M Member
    Ottawa, Canada
    True, but there are a couple of big ifs. I assume Tesla is improving designs so maybe the new part will last longer, plus there's some amount of randomness in these failures - maybe I was just unlucky. But you could be right - another reason to get the extended warranty.
  20. gpcordaro
    gpcordaro Member
    I just heard back from NHTSA on my worn or failed ball joints. They said that the were of poor quality and failed prematurely. They are looking for other examples or samples to test, to see if it is a bad batch at the production level or a bad design.
    If you have experienced a similar incident, I urge you to have the old parts saved by your Service Center and contact NHTSA for them to test the quality of the parts. This is a matter of Public Safety. Here is their contact information.
    Defects Assessment Division
    Office of Defects Investigation
    National Highway Traffic Safety Administration
    NVS-211 Rm 48-218
    1200 New Jersey Avenue. SE.
    Washington D.C 20590
    Phone - 202-366-5410
    Fax - 202-366-1767
    • Informative x 3
Thread Status:
