You had me sympathizing with ur plight until you said a Volt>Model 3.
Not a chance.....
Try closing a Model 3 door and the a Volt Door side by side.
Volt rides smoother. Gosh I’d do anything to avoid a speed bump in the Model 3.
It cost half as much.
It is much quieter (triple door gaskets)
It doesn’t slam on the brakes with Adaptive Cruise Control
CarPlay works great. I don’t really require Car Play if Tesla would just fix the many gaps, bugs in their implementation.
I can natively install Pandora,Spotify and others. (Separate from CarPlay). I can call up USB music by voice.
It has real Cross Path detection and real Blind Spot.
No it doesn’t go 0-60 in 3.1 secs. But I could care less about that.
I’m not afraid of hitting a large puddle in the Volt, nor worry about the rear bumper falling off. Or the roof cracking (again).
Oh, and the hatch is awesome and doesn’t pour water in the trunk.
has Heated wheel too.
I did very little research on the Volt honestly. I just found the 53 mile battery range would effectively make it a 99% electric use for what we will use it for. The fact that I’m floored by what I see, hear and feel is icing on the cake.
The stats it displays is much more extensive.
oh and it can come to full stop on regen. The regen boost button on the wheel is a blast. Does your model 3 have that?
I keep finding more stuff that it does that Model 3 didn’t do or do well.
That all said the Model X seems way better built than the 3. It better be for $100k. I think the Volt might still be quieter though. Sad but true.
oh and the panel gaps, which I generally could care less about. Wow, they are absolutely perfect and so is the paint on the Volt. They are “ok” on the Model 3 and X. But I know many members here would reject both my Tesla’s.
And something really odd is, I actually got the Windshield clean in the Volt with normal Window cleaner. I never got my glass clean in the Model 3. Still working on the X. There is more crap on that glass. So much crap you put with in Tesla.
I think the seats are nicer in the Volt with better Bolsters than the 3. But the X tops both. There is way to much chrome on the Volt dash though. Model 3 audio is a little better than the Volt. Model X tops both.
