I don't need to find or create an competing theory in order to invalidate yours. I've explained several times how your source data is questionable, and your assumptions created to support your theory. You're simply trying too hard to prove a theory that really has very little actual support of the facts. I'm not privy to Tesla Motor's inner workings, so I'm not even going to try and guess why they changed the EPA rating. But new battery chemistry is one of many, many, possible reasons -- marketing being probably the most plausible one.
You even fabricated one of your data points because you needed it to fit your theory:
What is the *real* range for a 60D? In fact, immediately following your post, this was posted:
Are you using your fabricated 60D range of 212 in your theory, or did you update it to use 225 as Tesla claimed?
And you seem to ignore or discount what was reported concerning the 70D battery pack:
Man, this is intense: “The lady doth protest too much, methinks”, “fabricated”...
I say that you are engaging in personal attack and need to cut on theatrics and chill-out. Doing breathing exercises before posting might help.
Going back to the essence of the issue, you, of course, disprove nothing. You actually did not really lay out all your objections clearly and consistently, rather side with others who note their objections, or attack things that are really peripheral to the conclusion of my theory.
So I will try to summarize your objections and rebut them here.
First, word fabricated is thoroughly out of place here. I openly, in great detail stated my assumption/calculation for everybody to see and evaluate, so ascribing intent to mislead and manipulate is simply wrong here. Most importantly, the graph is nothing to do with my theory – it is just graphical representation of the fact that increase in range observed in 70D is too large to be fully attributed to added 10kWh of battery capacity, or the addition of the dual motor drive. This conclusion is actually seem to be universally accepted by everybody.
More over, the simple extrapolation I did is the same as saying that increase in range of 60D over 60 is proportional to the increase in range of 85D over 85, a totally reasonable assumption, given that these are variants of the same car, with similar battery packs and drive train options.
Are you using your fabricated 60D range of 212 in your theory, or did you update it to use 225 as tesla claimed?
Not sure why you are asking this question, as I specifically explain that my point is based on this calculated range of 212. Using 225 miles at 65mph would be, of course, wrong as all range numbers I use are based on EPA range, not range at 65 mph.
Still too many unknowns (options, etc) and assumptions made to be able to make any scientific conclusions based on two weight data points. It’s really apples and oranges. Or apples and something else, Sorry
If you would actually spend some time reading the sources with weight data that I referenced, you would notice the following:
- The Car and Driver Instrumented Test article does list all of the options on the car: 19-inch wheels and tires, next gen seats, metallic paint, special wood trim and cold-weather package. The 70D was weighed at 4608lbs.
- The R&T article was published on the day of the D event, 14 minutes after it was scheduled to start. (October 9 2014, 7:14pm). It is clear that data in the article was **not** based on R&T sneaking out three variants of the cars from under the nose of Tesla folks and running them to the local scale to weigh them, and then stealthily returning the three cars to the unsuspecting Tesla. The data was clearly provided by Tesla and published as soon as news embargo was cleared with the start of the event. These data, as is the case with all manufacturer’s data list weights without options, unless stated otherwise. So the weight of the base 60D car according to Tesla data is 4597lbs (including 176lbs added associated with the dual drive unit).
- So these two data points are hardly apple and oranges. The options listed for 70D can’t add 90 pounds or so to the weight of the car that would actually make any material impact on my conclusions. In fact the 11 pounds difference between the two numbers is likely due to the cold weather package that is part of 70D, but not the 60D.
In conclusion, while I still call my musings on this subject a theory, it is a very plausible one. Your objections disprove nothing, as they actually are based on your assumptions which are inaccurate.
