CKwik240
It will simply change the nominal position of the ball. But as the ball is spherical, there is no difference regarding loads on the assembly. It's another thing altogether if it's reaching the limits of articulation, but if it's going that far, you have much bigger problems.The ball joint still rotates differently at different heights. I'm not saying they are actually causing increased wear. I'm saying that a modified suspension changes the kinematics and dynamics of the system. The mgfr has every right to believe that played a role in the failure.
I've already said all I need to say regarding warranty further up in the thread. My comment is purely about the ball joint.
Ball joints are functionally quite simple. But lubrication is a tricky task, and I'm not expert in that regard, but having attended engineering meetings with one of our ball joint suppliers regarding lubrication issues, nowhere in any of those discussions did position come up except for when it hit the limits of articulation. It's unlikely even a slammed M3 is going to be close. You'll likely run into damper limits well before then. You can use fancy words like kinematics and dynamics all you want. I've studied and applied both. I fail to see how lowering a vehicle will place any stress on the ball joint outside of it's designed specifications...
