Tesla haven't recognized a train
Discussion in 'Autopilot & Autonomous/FSD' started by Nickage87, Dec 5, 2020.
  1. Knightshade
    Knightshade Well-Known Member
    NC
    You don't need them there in the car either if there's an alternative way to determine the driver is paying attention (see Caddys system for example).
    Tesla has simply chose to use "interaction with wheel" as their monitoring system.
  2. antoinearnau
    antoinearnau Active Member
    Montreal
    You have a point, but there are an awful lot of reports of troubles with the AP and FSD.
    Also, I could be wrong, but did Tesla have another mean of control acceptable by the government ?
  3. dmurphy
    dmurphy Woof.
    New Jersey - Morris County
    Last time I checked, the 1500 hour rule was still in effect. And that's - as you said - bare minimums.
  4. Knightshade
    NC
    The vast, vast, vast majority being user error by folks too lazy to read the manual though.
    The government has nothing to do with it- there's no regulation of L2 systems at all.
    (well, I suppose it has to do with companies wanting to AVOID the government deciding they need to regulate it... but there's no specific requirements for any particular system as laws stand today).
    The steering wheel system was the cheapest/easiest one available in 2014 when AP1 launched, and they've doggedly stuck with it ever since.
    In part because Tesla keeps (so far wrongly) thinking they're just a year or two away from "real" FSD, where you no longer need a driver- so why bother dumping $ into checking their awareness when the car can drive itself?
    The 3/Y does have an in-cabin camera, but it's terribly ill-suited for driver awareness (wrong type, in the wrong position) and doesn't even exist in the S/X models.... the stated purpose of the 3/Y camera is... monitoring the passengers for doing damage to the vehicle when operated as an autonomous robotaxi... (see again Tesla keeps making design decisions in their cars as if they have already solved FSD)
  5. Kevy Baby
    Kevy Baby Dis-Member
    Brea, CA
    But it is still somehow Tesla's fault.
  6. dgatwood
    dgatwood Member
    Sunnyvale, ca
    Only if there's a ramp so you can jump through the empty flatcar.
  7. LACALawyer
    LACALawyer Banned
    That's very Trans-Am of you to say.... :)
    • Funny x 2
  8. LACALawyer
    LACALawyer Banned
    I'm kinda worried about the two people who marked this comment as "informative."
    • Funny x 2
  9. JulienW
    JulienW Active Member
    Atlanta
    #49 JulienW, Jan 3, 2021
    Here is FSD Bata trying to go through or around or under/over :D a train and he has to disengage after the hood was actually under the crossing gates and no sign of stopping. Oddly the display says "Stopping for traffic control in 25 feet". That is about 10' on the other side.:eek::eek:
    Since it is clear FSD Beta doesn't recognize trains, there is no way our current AP/FSD will.
    Time Stamp 16 minutes:
    • Informative x 2
  10. byeLT4
    byeLT4 Member
    Texas
    Looks really confused at the RR tracks with a train. It seems like it occasionally wants to add a road where the train is going, does it think the train is a bunch of trucks? Definitely needs work.
  11. LACALawyer
    LACALawyer Banned
    Driving forward when I can't see basically describes my life. :)
    • Funny x 3
  12. DaveG_NJ
    DaveG_NJ Member
    NJ
    Warminster line maybe?
  13. thewishmaster
    thewishmaster Member
    I don't think lidar is required for this specific instance - I might be oversimplifying but it looks like they need to add another classifier for trains to identify them as a single vehicle in the path. Based on the visualization each train car is treated individually and the motion planner attempts to make a run for it through the gaps it keeps seeing but missing due to reacting too slowly. Probably needs some custom behavior or training for knowing when to yield for trains the way it yields for cars/bikes/pedestrians.
  14. Hobojo153
    Hobojo153 Member
    Lidar wouldn't help here at all. All Lidar does it give you a much higher res, and depth mapped, though monotone view of the world. You would have to do basically the same type of image recognition to "see" a train with it.
    Maps also wouldn't solve this specific issue as they can only tell you if there's a train track at all. Not whether or not it's closed. (Assuming you're not hooking it up to a live train map feed)
  15. antoinearnau
    Montreal
    Out of context : "you don't need to see the train" :)
    A myope car will do !
  16. thewishmaster
    Yeah, for the majority of cases, but also incoming / already-visible trains in case for some reason the lights aren't flashing and the barrier is up
  17. Dan D.
    Dan D. Member
    Vancouver, BC
    Rule #1 still seems challenging. Don't hit anything. It was going for the train, or at least the barrier.
  18. byeLT4
    byeLT4 Member
    Texas
    Yup, and still several crossings around here with just the old crossbuck sign. No lights or gates.
  19. dgatwood
    dgatwood Member
    Sunnyvale, ca
    It needs to recognize the flashing lights even if there is no barrier. Most railroad crossings in rural areas don't have gates. If it had treated such a crossing like a flashing red light (stop and then go), the occupants of the car would likely be dead a few seconds later. When those lights are on, you do not proceed unless you can see the train and it is stopped. And even then, do not proceed unless there is only a single track. :D
    Ideally, it should recognize the sign, too, and if there are no lights at a crossing, it should stop well before it gets to the tracks, look down the tracks to see if a train is coming, and then proceed only if there isn't one. That said, I'd settle for it simply stopping before old-style unlit crossings and playing the "Take over immediately" chime, at least for now.
  20. Hobojo153
    Hobojo153 Member
    But they already can see that part. Even in the production build we have it rendering RXR markings and treating trail tracks as intersections to slow for.
    The point is that the problem is simply that they're not doing enough with the available information, not that they don't have enough information.
