qingshan
18 lr rwd fsd
I've not seen an EA L2 but the other providers often have both, particularly Blink and ChargePoint. Some EvGo are even putting Tesla plugs at some of the newer sites
The new generation of chargers like the typical ones at Electrify America all have a peak voltage output of at least 920V and some are 1000V. The “150kW” chargers are rated at 350A peak amperage and the “350 kW” are rated at 500A peak amperage.Some of the highest power EA stations are listed as 320 KW, others are labeled as 350 KW Is that a labeling convention difference or a real difference with some rated for 800V at 400 amps (320 KW) and others rated at 1000V at 350 amps (350 KW)?
I wish manufacturers of CCS chargers would just list max amp and voltage available. Very frustrating in the Bolt to pull in to a 50 KW station to discover it is rated at 500V at 100 amps.... gives around 37 KW on a 400V system like the Bolt has. Other 50 KW CCS are actually 400V at 125 amps, this provides 45 KW to a Bolt.
Electrify America has 2 categories of charging sites.I've not seen an EA L2 but the other providers often have both, particularly Blink and ChargePoint. Some EvGo are even putting Tesla plugs at some of the newer sites
Highest power J1772 I have heard of is 48 amp 240V (11.5 KW) and that matches the fastest L2 speed of the MY LR and MY P, the MY SR+ maxes out at 32 amps, (7.8 KW)So it sounds like to really take advantage of the EA network, you'd want the CCS adapter. Otherwise, using the J1772 adapter, you'd be limited to pretty slow charging (I think something like 19kW). Was just curious because we have a timeshare on Cape Cod, and there are only 4 SC locations on the Cape and getting to them in the summer could be difficult due to traffic - and I suspect they will be busy. Although the closest one is only about 10 minutes from our timeshare, which is what I plan to use.
I pull 48A 11kw from my ChargePoint home flex, every dayHighest power J1772 I have heard of is 48 amp 240V (11.5 KW) and that matches the fastest L2 speed of the MY LR and MY P, the MY SR+ maxes out at 32 amps, (7.8 KW)
Keith
And?I pull 48A 11kw from my ChargePoint home flex, every day
No, but I swore your comment earlier said 9kw and 40 amps…lol it was early so maybe I’m seeing thingsAnd?
Are you worried about not getting 11.5 KW like I said you should? Don't worry, it is a rounding error.
Keith
We have all been thereNo, but I swore your comment earlier said 9kw and 40 amps…lol it was early so maybe I’m seeing things
Cool, too bad we are limited to 11.5 KW
Per Map of 70 Amp J1772 chargers, there were some 70 amp public J1772 EVSEs at some the location listed there.
We? My 2015 S85D is not. It Accepts 80 A, which provides 19.2 kW at 240 V.Cool, too bad we are limited to 11.5 KW
Keith
However, there is no pressing need for more than 48 A AC charging. There are only a few edge cases where it helps.
This for CCS2 (Europe CCS). It seems likely that the CCS1 (USA/Korea) adapter will be the same but I don’t think we know yet.Insideevs has an article on charging a Tesla with a CCS station. Below is a chart from it. You can find it by searching for Tesla charging at a CCS station.
I realize it's a year late (almost to the day), and @cwerdna mostly answered this already, but keep in mind you are looking at this with (a) the benefit of hindsight and (b) without taking into account the competitive aspects of the EV market. I just discovered this thread and thought I would weigh in on a few other aspects to this question, which are important.Hey smart people... why did CCS become the standard anyway? What are the advantages of it? A big disadvantage is it is larger in size to the Tesla connector. It appears the Tesla connector should have become the standard.
