4 chargers per station are enough for a lot of places.
How often do you think more than 4 people are going to charge at the same time in Wall, SD?
If it's the only fastcharger >50kW available on I-90 in SD, I imagine it could potentially be a bottleneck. And if 1 or 2 stalls are down.
The problem is that you assume that the rest of the country is New York, when in fact, the majority of the country is very rural.
Yes, on the flip side, Wall, SD may be very rural, and likely would not have as much traffic at a given site. However, given the extremely low density of chargers along that route, it's even more important that the chargers that are there are available.
(also, speaking as a native New Yorker that grew up in a quaint town of 4000 (and this was the biggest town in the county), which is like a metropolis compared to where my in-laws live (the nearest gas station is about 45 minutes away), I would also like to caution against assuming that New York is not rural. Huge portions of it are indeed quite rural and without really great charging station coverage.
That said, unlike
@cusetownusa 's NYS charging experience, mine has been pretty good. You might need to do a bit of research on Plugshare to know which stations to avoid (seems like
@cusetownusa cherry picked at least one loser of a site to exhibit). There are a couple of stations that I specifically avoided due to unfavorable reports on Plugshare, or too few stations (1 or 2) per site, but I had good experience in Syracuse (okay, this is not rural), Watertown, Waterloo, and Canton (only 24kW charging at this one, but it worked fine).
I don't know if the average Joe is going to be willing to do as much research as I did to avoid getting stranded. For all I know, they may not even do much research to find out of the way charging stations at all. They may stick with the major networks. And as others have said, a poor experience at these networks if they can't get things working well is going to leave a sour taste in the mouth of new EV owners. That bad first impression is hard to get over.
It's all well and good that you have excuses like bad temp sensors and motherboard shortages and so on, but at the end of the day, these stations are broken or underperforming, and this is a real problem that you can't just sweep under the rug. The new EV driver that is going on their first road trip and winds up stranded or taking twice as long to make the trip because of a broken charger is not going to just say, well, it's the motherboard shortage you know.
